Old 05-06-2021, 03:03 PM   #1
2016 16' Sport
Charlotte , Iowa
leaking cold water bypass valve on water heater
I was dewinterizing my 2016 Bambi Sport today and discovered a leaking valve in the water heater bypass . I think it is the cold water valve. Can someone tell me how to remove the leaking valve and replace it with a new one? Any help would be greatly appreciated
boocanoe is offline   Reply With Quote
Old 05-06-2021, 03:20 PM   #2
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
A pic can help identify possible techniques.
If it's attached with PEX tubing, goo news you don't need to buy expensive PEX ring clamp tools. Alternative fittings exist, no tools or simple hand tools only.
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Dexter 4 Piston Disc Brakes, Carslile Actuator, Equal-I-Zer, Dill TPMS. Campfire cook. BMV-712
GCinSC2 is offline   Reply With Quote
Old 05-06-2021, 04:51 PM   #3
2016 16' Sport
Charlotte , Iowa
picture of cold water bypass that is leaking
Hello,
I have uploaded a photo of the bypass valves. Any assistance would be greatly appreciated. Hoping to be able to fix it myself.
Thanks.
Old 05-06-2021, 05:14 PM   #4
GCinSC2's Avatar
Looks like decent access that’s a plus.
When you’re positive about source of leak, at least this is my approach.
A hacksaw blade can cut the copper clamps at each end of the pipe at a fitting. Carefully remove the valve and short sections of the pipe.
Take remains to hardware or home center as I need this but new.
Pipe should be PEX a short stick, new valve and now how to clamp.
I have a small survival kit of PEX and the Flairit by Pexlock clamps. These slide on the pipe and a simple channel lock pliers set the clamps. They are even reusable.
S/OS #001
Hot Water Heater Bypass Valve Access donreitz 2009-2015 Flying Cloud 6 02-12-2021 03:54 PM
Location: Water heater bypass valve? Will_Brule Water Heaters, Filters & Pumps 17 10-08-2019 04:06 AM
Water heater bypass valve lucybear Water Heaters, Filters & Pumps 20 10-18-2017 09:09 AM
Water heater bypass valve on Interstate Ext Lounger drguthman Our Community 0 01-23-2017 06:51 PM
Water heater bypass valve Robfike General Motorhome Topics 6 05-11-2014 06:21 PM
