Leak outside- under kitchen sink 2014 23' FC
Well, I thought I had the problems solved with a leak in the fresh water tank fixed. Now, I have a small leak that manifests itself by water coming out when the gas line goes into the trailer bottom aluminum cover just below the sink. I thought I could take some screws out and lift the shelf under the sink, but that is not working. I am guessing that the cabinet under the sink was put in as one unit, and I assume that removing the screws that attach it to the wall and the panel next to the stove would allow a person to get all the cabinets out of the way. Nothing is wet under the sink so it has to be in the plumbing that is hidden behind and under the cabinet. It only leaks under pressure, so it is not the drain. Any advice on how to tackle this problem? I want to get this fixed right away so I don't have floor issues. Thanks
