Old 02-17-2021, 08:35 AM   #1
Kansas City , Missouri
Leak after freeze in Texas
Hello out there.
I am a new 65 Caravel owner as of November.
I have come down to gulf of Texas, and WOW it froze for the first time in a long time.
I tried all the tricks and was hopeful my pipe were okay, but last eve after things had thawed I was getting water leaking inside.
I am ashamed to say I do not know much. The owner I bought it from was not sure what PEX was, so I did not get much information. If I could find the previous owner to that owner, I could get some better understanding of things since it was renovated by that person.
Anyway, I am providing a pic of where I think the leak is, if anyone has advice? I may be way off but it seems to be right where there is a joint ?
Also someone where I am staying asked if I had turned the water heater off(electric). NO! OMG I am so glad, because it was WARM on the floor. I turned that sucker of really fast.
Again, this is all new, so please be kind...if anyone can advise.
Thank you,
Kerri
rambler1970 is offline   Reply With Quote
Old 02-17-2021, 10:40 AM   #2
pjshier's Avatar
2017 27' International
Wasilla , Alaska
take photos to hardware store
Looks like you found a leak and it looks like the access is not too bad. Not directly familiar with that fitting, but a plumbing supply should be able to tell you how to remove and replace it. Similar SharkBite fittings have a small tool you can use to remove their fittings - this one may be the same. Might take a couple of trips to get a replacement that fits if you can't accurately measure the outside diameter of the pipes before you go.
2017 Int'l Serenity 27FB
2020 F250 powered by converted solar
pjshier is offline   Reply With Quote
Old 02-17-2021, 11:05 AM   #3
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
Your fitting is a Sea Tech and most likely the 1/2" pipe size. Replacements can be found at Camping World, on Amazon (search "sea tech fittings"), and RV or Marine stores.
Sea Tech is now AquaLock, owned by Watts. A link to the manufacturer's site:
https://www.watts.com/aqualock-marine
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Low Point Drains After Anti Freeze Thomas2 Plumbing - Systems & Fixtures 4 12-31-2017 07:32 PM
After a freeze blueheart Plumbing - Systems & Fixtures 2 02-19-2017 06:14 AM
winterizing - removed water filter - will it leak anti-freeze? Pudentane Fresh Water Systems 8 02-19-2013 09:39 PM
Water Dripping From Fan During Freeze/Thaw/Freeze/Thaw Fly at Night Roof Vents, Skylights & Fans 5 12-16-2011 10:54 AM
No Anti-freeze smily Plumbing - Systems & Fixtures 8 04-15-2003 11:11 AM
