Old 07-03-2020, 07:27 PM   #1
Spring hill , Florida
installing new faucets designed for house, need help with connecting to grey poly
I have installed standard household faucets and have standard female 3/8 braided lines but grey polybutylene pipe, been to several big box home stores and getting no help, I wonder if someone here would know what I can use to connect the two, I have. very limited knowledge on plumbing, and any help would be appreciated, I like pictures too lol. thank you in advance.
Nshipe123 is offline   Reply With Quote
Old 07-03-2020, 07:37 PM   #2
Is it January yet?
jaybauman's Avatar
2019 30' Flying Cloud
Katy , Texas
Full disclosure: I'm not a plumber. (My father is, but apparently it's not genetic!)
In the past, I think I've used a SharkBite fitting to go from polybutylene to NPT. Does that not work for you?
I find the guys who work at my local hardware store to be quite a bit more knowledgeable than the "big box" boys. Take what you have to your neighborhood hardware store and let them give you a solution. This works for me when I hit the end of my plumbing knowledge.
2019 Flying Cloud 30FBB
Bunkhouse is sold...something more "classical" on order!
2020 GMC 3500HD Duramax AT4
ProPride 3P w/ 1400 lb. spring bars
jaybauman is offline   Reply With Quote
Old 07-03-2020, 11:56 PM   #3
57Vintage's Avatar
1958 26' Overlander
Battle Ground , Washington
Images: 22
Suggest you use a standard shut off valve and then adapt to your lines. I have expansion ring pex so I just ordered drop ear elbows to secure to the cabinet and adapt to size of my lines.
Name:	hot water bypass line.jpg
Disregard the circled fitting that was about a different topic.
Harold & Rebecca
Our thread:
https://www.airforums.com/forums/f97...er-172124.html
57Vintage is offline   Reply With Quote
Old 07-20-2020, 09:16 PM   #4
1989 25' Excella
Greenbrier , Arkansas
Attachment 371911
Interested to know where you ordered these elbows,,, are they a standered that matches up with the existing faucet supply fittings at the sinks?
stkwhittler is offline   Reply With Quote
Old 07-20-2020, 09:56 PM   #5
57Vintage's Avatar
1958 26' Overlander
Images: 22
I ordered mine through Supply House. They refer to the expansion ring fittings as ProPEX and are made by Uponor (Wirsbo). They seem to have the largest selection of fittings for ProPEX. They also carry crimp, Shark Bite, Blue Fin and others.
https://www.supplyhouse.com/sh/contr...+elbows+propex
I used the fitting with 1/2" propex and 1/2" female NPT (FIP) to match up to the shutoff valve.
https://www.supplyhouse.com/Wirsbo-U...-PEX-x-1-2-FIP
Just a reminder to order lead free fittings for use on fresh water lines.
Harold & Rebecca
Our thread:
Old 07-21-2020, 06:33 AM   #6
1989 25' Excella
Thanks Harold,,,
Looks to me like you did things the easy way,,,,, replaced everything,,,,
Smart way too I might add..
Because ours is so new, 89, we’ve not had to venture in to the grey pex world of fixes before,,,,
Main problem, I’m a carpenter at heart, but, I can sweat copper and glue pvc, but have never ventured into the world of crimping tools,,,, where do you even start buying the tools for late eighties grey plastic,,, are those type fittings the same as those used today’s?
I may just have to leave the old sinks in,,, I think I can patch the holes I the new counters and they will look fine... I’m a pretty good carpenter,,,,
Old 07-21-2020, 09:41 AM   #7
57Vintage's Avatar
1958 26' Overlander
Images: 22
Sorry, can't help you on the gray plastic, never used it.
I know a lot use Shark Bite and are very happy with it. One of the reasons I went with expansion ring is my current house is the same and that helped justify the expense of the tool needed. We have 2 room remodels planned and both involve changes to water lines.
Harold & Rebecca
Our thread:
2016 grand tour - question on connecting house batteries Rjlyons Sprinter and B-van Forum 10 06-14-2020 04:44 PM
Help, Are my waste tanks ABS or Poly? dwhitake Waste Systems, Tanks & Totes 5 02-21-2019 02:33 AM
Connecting 50 amp Classic to house service mikeinca Electrical - Systems, Generators, Batteries & Solar 76 09-27-2017 06:07 AM
Connecting TV to House Sound in Interstate stast01 Audio, Video & TV 0 10-26-2016 12:07 PM
Connecting to a house jpsuttoniii Full-Timing 2 04-16-2013 02:44 PM
