Originally Posted by gjmovinon
Looking for someone who can tell me where the fresh water holding tank drain valve is located on a 95 Land Yacht LE 30 foot.
Welcome to the forum!
Do you have the owner's manual?
You might find a more receptive audience in one of the motor home forums IMO:
http://www.airforums.com/forums/f156/
Land Yacht etc.:
http://www.airforums.com/forums/f312/
FYI the new search function in the blue box above works very well. Here are the results for "land yacht water tank drain" --
https://www.google.com/search?q=land...=airforums.com
I think this may be your manual:
https://www.airstream.com/wp-content...-LE-Series.pdf
The water system text starts on p. G-4 [PDF p. 68/212], but I don't see anything about water tank drain. On p. G-7 they use "drain" re: cleaning the tank with bleach FWIW. Drain valves on p. G-17.
Good luck,
Peter
