Old 09-06-2018, 12:07 PM   #1
Avon , Ohio
Front storage - drain
2019 FC 25fbq has a white drain just to the left inside front storage compartment. Looks exactly like the fresh water drain under the camper. It seems to be in the same vicinity as the hot water heater but there is access to the hot water heater on the outside. Would this be another low point drain?
Jlinkous14 is offline   Reply With Quote
Old 09-06-2018, 05:04 PM   #2
2018 25' International
2002 30' Classic
1995 30' Excella
Ellensburg , Washington
I think I have the same thing on my 2018 Serenity 25FBT. I also have a valve in the storage compartment to the right of my water heater. I just posted my question about what this is on the current Intl. forum with pictures. I am waiting for the intelligent people on here to know right away what it is for.
I can get back to you when I find out, or I will monitor this as well for the answer.
Good luck to us both.
dcineb is offline   Reply With Quote
Old 09-06-2018, 05:23 PM   #3
2002 30' Classic
1995 30' Excella
I've heard from 2 knowledgeable people that said this is a low point drain to drain the system for winterization. Having trouble entering my pics here but if you want you can look at my post (under my name).
Old 09-07-2018, 06:49 AM   #4
Avon , Ohio
Correct. Spoke to a dealer yesterday and it is in fact just a drain for your hot water lines.
Thanks.
Cold fresh water valve and drain in the storage compartment DJW Fresh Water Systems 6 04-06-2016 09:45 AM
Battery Drain During Storage ltorgy Electrical - Systems, Generators, Batteries & Solar 16 07-03-2015 10:49 PM
Re working kitchen drain- pex for drain lines?? bwilson1 General Repair Forum 4 04-20-2014 08:42 PM
Drain water for below freezing storage? ldetsf Winterizing, Storage, Carports & Covers 3 11-28-2006 07:47 PM
A/C Drain ...leaking at drain hose connection Sav'h Steve Furnaces, Heaters, Fireplaces & Air Conditioning 5 08-01-2004 04:09 PM
