Old 10-02-2024, 11:27 AM   #1
2018 23' International
Germantown , New York
Fresh Water Says Open?
So I don't have much faith in the accuracy of the tank sensors anyway.....but now the fresh water tank has been saying 'OPn' - I'm assuming 'open'!
This happens off and on. Sometimes it gives a percent and seems to be accurate, sometimes not.
The tank is full to the point of overflow by the outside fill cap. The pump is primed and air purged. It doesn't matter if the pump is on or off - same message 'OPn'.
Thoughts?
TBone55 is offline   Reply With Quote
Old 10-02-2024, 02:33 PM   #2
2019 30' International
Pennsylvania , Pennsylvania
Thoughts?
Pull that display off the wall, unplug it for a minute, then plug it back in...see what that does for it.
Otherwise, https://www.garnetinstruments.com/wp...anual_v3.1.pdf
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 4:30 rear Leer Topper Ruby Red
2019 International Serenity 30 Rear Twin
majorairhead is offline   Reply With Quote
Old 10-02-2024, 02:59 PM   #3
Will give that a shot tomorrow. Thanks for the info!!
Old 10-02-2024, 03:36 PM   #4
2014 27' FB International
Lewisville , Texas
More Info
You can download the installation manual on the manufacture’s web site, and it includes a troubleshooting guide. It also has some other beneficial information such as how to set the display brightness , calibration and a model that has Blue Tooth. Yours is in this list called:
"709 SeeLeveL II Series / Display Manual for all 709 Models v1.1 / Display Manual, Manual"
https://www.garnetinstruments.com/ho...ource-library/
I also found by a web search, some instructions for resetting the Monitor:
To reset a SeeLevel II Tank Monitor, you can try these steps:
1. Press and hold down the button for the tank you want to check
2. While holding down the tank button, press and hold down the BATT button
3. Continue holding both buttons until the display shows "dIA" (diagnostics)
4. Keep holding both buttons until the display enters programming mode, which should take about 5 seconds
A few years ago, when my Monitor was giving some inconsistent readings, I took a chance and replaced the Monitor only. It was the best hundred bucks I ever spent, it has been working perfectly ever since
I got my monitor here:
https://www.rvupgradestore.com/Seele.../709-p3-mo.htm
Best of luck
NO NOIZE is offline   Reply With Quote
Old 10-03-2024, 11:40 AM   #5
2016 30' International
Redmond/Tucson , Oregon/Arizona
OPn = open circuit as per the above suggested Garnet manual.
davetoregon is offline   Reply With Quote
Old 10-09-2024, 09:14 AM   #6
Troy McLure's Avatar
2016 23' Flying Cloud
Portland , Oregon
I just had this after an electrical upgrade.
This is one solution but there may be other reasons for the Open code.
The low voltage line doesn't like being near other power lines. They cause interference. I had to move around some wiring in the belly pan to keep the thin blue and white wires leading from the sensors to the panel away from other power lines. Once I did that, the Open code went away.
This may not apply to you but if the wiring heading into the panel checks out, you need to check the other end. You'll need to get access to the belly pan near the dump port. That's usually where the sensors are.
Troy McLure is offline   Reply With Quote
Filling fresh water tank 2019 airstream fresh water fill problem arvaterry Fresh Water Systems 15 07-07-2024 08:09 PM
Open or not open, that is the question RoadHungry On The Road... 58 06-22-2015 03:47 PM
Outside fresh water door lock won't open willbrackman Exterior Storage Compartments & Access Doors 12 11-02-2011 12:27 AM
fresh water drain valve/open & close billiards Fresh Water Systems 7 07-22-2009 06:10 PM
Tag says 22T-0102 958 9-7-58 is it worth $900.??? leefields Trailer Values 12 10-12-2004 05:49 AM
