Old 03-19-2020, 12:51 PM   #1
1979 31' Excella 500
High Springs , Florida
Flexible air hose in bathroom?
We are renovating a 1979 Excel 31 foot AS. We have an air vent pipe that needs to be replaced, we would also like to use a very flexible hose instead of the hard one that is in there. The hose is 1 1/2". What are some thoughts on this. The reason being, the hard pipe will interfere with our new bathtub placement. If we could use a flexible hose it would make it easier to do. This pipe or hose is for air flow only. Hooked behind the bathroom sink and goes up and out the wall, near the ceiling.
Thanks so much
janharrod is offline   Reply With Quote
Old 03-19-2020, 12:58 PM   #2
Jeffersonville , Kentucky
I used a flexable plastic pipe for both my front and back vent
So far no issues. it is just air.
Dremel is offline   Reply With Quote
Old 03-19-2020, 02:05 PM   #3
batman's Avatar
1964 22' Safari
modesto , California
I used a flexible pipe for my grey tank vent as well. No issues at all. Properly sealed and clamped you should be OK. These are only vent pipes and do not have liquid passing through them. However, what I did was to go straight up with ridged ABS (back pipe) from the highest TEE then connect the flex at that point, then to the top vent pipe also ABS sticking out the top. So two transitions (in my case). Maybe a photo, here you go.
Sorry! It's not sideways in my photo's. I guess you have to tilt your head . Hope it helps
-Dennis.
batman is offline   Reply With Quote
Old 03-19-2020, 05:13 PM   #4
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
I would use flex if I need to.
Some options that come in 1.5":
wet-dry vacuum hose
pool vacuum hose
spa hose
water filler hose (same as the fresh water tank filler)
ps: don't reduce the size of the hose, or the tank will drain slower than it does now.
Alan
Old 03-20-2020, 11:42 AM   #5
Married with Airstream
drbrick's Avatar
2004 25' International CCD
Vancouver Island , British Columbia
Sounds like a workable plan!
La Dolce Vita Brick & Mona
We're Married With Airstream
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD FX4 SuperCrew Lariart (MaxTow) "Red Dragon"
drbrick is offline   Reply With Quote
A hose is a hose is a hose Vitaver Plumbing - Systems & Fixtures 37 02-06-2018 01:53 PM
Flexible shower hose TheCabin Sinks, Showers & Toilets 4 05-09-2016 12:31 PM
Thetford flexible hose adapter firetech51 1978- 1979 Excella 500 2 04-07-2016 05:22 PM
"Slunky" flexible sewer hose support, good condition! leong1 Airstream Classifieds 0 11-12-2014 02:31 PM
HD flexible hose OK? TomW Fresh Water Systems 8 10-17-2004 11:50 AM
