Old 08-06-2017, 06:57 PM   #1
drew05's Avatar
2011 25' FB Flying Cloud
Peculiar , Missouri
Exterior Shower Upgrade
Has anyone replaced the outside shower with the Stainless Shower Compartment from Airstream? If so how difficult was it?
I was told it was a simple removal and replacement, but when I tried to pull the compartment out, it feels like there is little or no play/slack in the water pipes.
Can it be done completely from the outside, or did you need to remove panels from the inside? I have a 25' 2011 FB Flying Cloud.
drew05 is offline   Reply With Quote
Old 08-06-2017, 08:08 PM   #2
jayseejay's Avatar
2015 27' FB Eddie Bauer
Fernandina Beach , Florida
We were able to install it from the outside, but it was a tight squeeze to reach in and loosen/tighten the pipe fittings, and in our case (2015 EB 27), we had to use a dremel to slightly expand the aluminum opening; the rounded corners of the opening needed to be squared off to make the new SS unit fit. Joe
jayseejay is offline   Reply With Quote
Stainless steel upgrade for TV/Sat connection and exterior electrical outlet on curb GLovedahl Exterior Storage Compartments & Access Doors 2 03-13-2015 07:38 AM
Possible to add exterior shower? air2stream Full-Timing 12 06-23-2009 11:29 AM
Exterior shower finished! Resorts Sinks, Showers & Toilets 23 07-25-2007 03:29 PM
Exterior Shower!!! Resorts Plumbing - Systems & Fixtures 17 07-11-2007 09:37 AM
Exterior Shower Leak Gkiesel Sinks, Showers & Toilets 5 06-12-2007 01:26 PM
