Old 08-03-2020, 09:26 AM   #1
Ultraclassic's Avatar
2000 30' Excella
GTA , Ontario
Black Tank Valve NOT sealing Repaired! 2000 30' Excella Classic
Well this is the Update on Stella since we got her in June. We love her and have been to a KOA and 3 Provincial Parks so far.
Two weeks ago I noticed that the black valve didn't go in all the way like the grey valve did?
But the trailer is fairly new to me I'm still getting to know her. I did a few flushes and still the same result.
So last week I stopped at the dump station after a week of dry camping, I made sure I was ready to "remove cover and slip on the hose Very Fast", because I wanted to be ready for "action"
I'll spare you those pictures but I survived without getting too messy.
We are heading out next week so I have only this weekend to investigate the problem and maybe order any parts and fix it before we go. Or put it back together and do the "remove cover and slip on the hose Very Fast" trick again (hopefully not).
I used my Anderson Jack to raise the left side of the rig up and remove the left rear wheel for better access and to keep any "Liquid" from dripping and dropping on me while I am laying under it!
Stella being 20 years old meant that this is not the first she has been repaired "down there"
I was pleasantly surprised to find that after removing a trap door, the previous repair was done with future serviceability built in and that the valves looked like new. Shout out to Can-Am.
I was able to remove the black tank valve dis assemble and remove a build up on gritty "stuff" stopping the slider from seating. I wet sanded the plastic to make it smooth, cleaned and lubed the seals, out it all back together, fixed and sealed the belly pan access panel, freed up and adjusted the black handle (so it fits in the lock rings) and good as new.
I didn't post the gross pictures, but thought "who has been here, know what I saw"
Cheers Mark
ID:	374848. All done
ID:	374835Click image for larger version
ID:	374844Click image for larger version
ID:	374845Click image for larger version
ID:	374846Click image for larger version
Tow Vehicle 2005 Ford F150 Lariat 367,000Kms 5.4L - 2012 Mercedes Benz GL350d - [not set up yet, should i?]
Ultraclassic is offline   Reply With Quote
Black tank valve not closing. Here's the reason. Brainodo Waste Systems, Tanks & Totes 22 08-08-2020 07:39 AM
Black Tank Valve Not Turning on eyechip Sprinter and B-van Forum 9 05-12-2020 10:46 AM
Black Tank Valve Stuck in ON. Tank not emptying. eyechip Sprinter and B-van Forum 3 09-25-2018 10:07 PM
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
HELP frozen black water tank, not valve Charlotte A Full-Timing, Winter Living & Workamping 21 01-20-2009 03:37 PM
