12-18-2016, 06:15 PM
2021 27' Globetrotter
Fort Lauderdale
Drip, drip, drip. Or not to drip?
Subfreezing temperatures is CO with a Camco water hose heater, ( https://www.amazon.com/Camco-22911-H...ot+hose+freeze ) we are told that we still should leave the city water drip at all times so water won't freeze. Anyone with knowledge on this?
GT 27 2021, F250 2022 Platinum- 2022 Tesla X - 2021 Ford Mustang Mach E - 2022 Tesla 3 - PP3 hitch
GSD Sigrid - Fort Lauderdale, FL; Denver and Summit County, CO.
12-18-2016, 06:17 PM
2008 27' Safari FB SE
Miami
SOP in Yellowstone. Your choices are basically to do the drip routine or to unhook your fresh water line and use your internal tank until the temps moderate.
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
12-18-2016, 07:05 PM
2006 23' Safari SE
Biloxi
, Mississippi
Recommendation if disconnecting the hose to bring it inside. They are very hard to handle in freezing temps.
MICHAEL
12-18-2016, 07:08 PM
Vintage Kin
Fort Worth
Systems on well water may not allow drip.
12-18-2016, 09:27 PM
1960 28' Ambassador
1998 25' Safari
Avonton
Dripping is of no use in real cold. I have seen Niagara Falls freeze over
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
12-19-2016, 04:59 AM
2016 23' International
Centennial
I have a pond in my yard that runs 24/7. While the waterfall does get ice on it, the water keeps flowing into the pond. Moving water won't totally freeze.
Steve "Centennial Man"
12-19-2016, 12:33 PM
1967 26' Overlander
Spartanburg
, South Carolina
Originally Posted by Vitaver
If any part of the water supply is unheated above ground you should let it drip. In our case, the copper line from the connection at the rear of the trailer is about 12 inches long and is partially outside and in unheated hose storage space. It pays to know exactly where all your piping is so you can take appropriate action.
12-19-2016, 01:03 PM
tonkawa
, Oklahoma
Please make sure if you decide to drip that your grey valve is open and your sewer hose can handle it. You need a good, even slope with no dips or the sewer will freeze up at those temperatures. Been watching my neighbor with his propane blower for the last two days trying to get his unthawed. If the sewer freezes the water backs up and will flood inside if you don't catch it in time. My neighbor has a tub full of stinky water he has been scooping out. If you are going to be in one place for a while you might want to go with solid drain pipe. It helps a lot. Also watch what faucet you drip as some trailers run their bathroom sinks into the black tank. That can be a REAL disaster.
12-19-2016, 07:08 PM
2013 31' Classic
billings
, Montana
If very cold a drip will freeze, a slow steady stream will keep running, found out in a trailer house I lived in....
12-19-2016, 07:25 PM
Palm Desert
Depends on the temp of the source water. For Niagara, the upstream water could be at or near 32deg. For dripping at a camp site, the upstream water could be quite a bit warmer if sourced from underground pipes.
2006 Cayenne S with V8, air suspension, factory tow
2018 FC 27 FB
2017 FC 25 RB Gone
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Drip, drip, drip
Skamper1 |
Fresh Water Systems |
8 |
06-12-2010 06:33 PM |
drip- drip-drip-drip-drip....
AIR-Quarius |
Furnaces, Heaters, Fireplaces & Air Conditioning |
3 |
08-09-2009 07:32 AM |
Arrggggg! Drip, Drip, Drip—Warning, plumbing questions
Jim & Susan |
Sinks, Showers & Toilets |
16 |
06-10-2009 08:04 PM |
Drip, Drip, Drip
kamadeca |
4 |
05-20-2008 08:22 PM |
AC drip,drip,drip,drip,drip
Canuks |
6 |
06-02-2006 02:05 PM |
