Old 02-27-2021, 03:49 PM   #1
2019 28' Flying Cloud
Dripping Springs , Texas
DIY pressure test & 'blow out' valve
I didn't winterize my AS and learned the hard way about ice damage. To diagnose the problem I created a gauge & valve combination, will share the parts list here.
Advantages:
- Can be used as a pressure gauge for leak testing
- May also be used as a 'blow out' air inlet
- No separate ball valve needed to turn off air, regular Shrader valve is used
- Very compact design
Assembly:
- Just screw everything together, use pipe tape
- The gauge has a valve but I just used a dab of epoxy to glue it open. It is NOT a pressure regulator
Use:
- Screw it into your fresh water inlet
- Use an air compressor with a tire inflator to pressurize (eg. 30psi, max 40psi)
- Empty your system by opening a faucet
Parts, all from Home Depot
Kalashnikov is offline   Reply With Quote
Old 02-28-2021, 01:07 PM   #2
kidjedi's Avatar
1972 25' Tradewind
1976 31' Excella 500
1974 31' Excella 500
1975 24' Argosy 24
Denver , Colorado
If your air compressor already has a gauge and you have quick connect fittings, something like this is great as well...
https://www.amazon.com/Litorange-Lea...dp/B07KWXVRSL/
edit: but I usually unhook my water pump (and take it inside) and blow from there rather than the city hookup... the best place will vary by trailer setup.
25' 1972 Airstream Trade Wind Land Yacht (heavily customized)
2006 Jeep Liberty CRD (diesel)
BeahmStream.com
kidjedi is offline   Reply With Quote
Old 02-28-2021, 01:11 PM   #3
B. Cole's Avatar
1977 31' Sovereign
Rochester , WASHINGTON
I got baited in, I thought this was a tire thread
Carry on!
Airstream rodeo clown, it's my turn in the barrel 🤡
B. Cole is offline   Reply With Quote
Fast Blow or Slow Blow Fuses? SilverWind Batteries, Univolts, Converters & Inverters 0 09-14-2018 02:23 PM
Help! Tire blow out and ripped out gray water valve pull rod marcesq General Repair Forum 13 06-24-2018 09:46 AM
Tire blow out took out rocker panel behind tire, need advice / suggestions ClayDC Belly Pans & Banana Wraps 15 04-25-2017 02:02 PM
If I Did a 'Blow Out' Of the Water Lines and No Water Came Out Did I do it Wrong? mrpettit Winterizing, Storage, Carports & Covers 15 12-03-2014 09:51 AM
Newer AS (2008) - correct air pressure to blow out water lines bonginator Winterizing, Storage, Carports & Covers 17 10-04-2012 08:47 AM
