Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures
Old 07-08-2019, 03:38 PM   #1
1975 31' Sovereign
Pinson , Alabama
Constantly leaking filter
This little filter was cracked and replaced. New filter is leaking also. Located under kitchen sink. Any suggestions?
ID:	345833   Click image for larger version
hnspaulding is offline   Reply With Quote
Old 07-10-2019, 02:00 PM   #2
waninae39's Avatar
2022 25' Flying Cloud
NCR , Ontario
replace with a modern filter
for the sink, we use a standard triple filter with removable filter bottles
for the trailer, we use a high flow rate filter
get a copper to pex connector and use pex on the new connections
waninae39 is online now   Reply With Quote
Old 07-10-2019, 03:37 PM   #3
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
While you are in there doing that, replace the black "hose" stuff as well. If it's been there since the trailer was new, it's due for a refit.
Will paper air filter change dynamics of engine with K&N filter? Astrodokk Mechanics Corner - Engines, Transmission & More... 23 09-05-2016 02:24 PM
Circuit Constantly Tripping maallen3 Electrical - Systems, Generators, Batteries & Solar 11 04-14-2011 07:08 AM
Dometic RM2501 constantly runs the igniter? blows fuse... WineStream Refrigerators 19 08-30-2009 07:09 PM
Furnace fan runs constantly rogerdavis Furnaces, Heaters, Fireplaces & Air Conditioning 10 10-10-2006 04:25 AM
