Greetings elhoppy7!
Welcome to the Forums and the world of Vintage Airstream ownership!
Originally Posted by elhoppy7
We just bought a 1966 28' Ambassador. Its in pretty rough shape. We will be gutting it but there does not appear to be any dump valves on the outside of the camper and we can't figure out where the black, gray and fresh water tanks are. Are these all enclosed under the floor? It looks like there is a covering over the bottom of the camper in the back. Is this where all of the plumbing and valves are held? I would just like an overview explanation of this configuration. Thanks!
With Vintage Airstreams of this era, the dump valve was often accessed through the rear "one-stop" service compartment. The Thetford valve should be in the near vicinity of the toilet. I am not sure whether Airstream had switched back to the above floor black water tank or if they were still utilizing a below-floor black water tank similar to my
1964. The one way to tell is if the toilet is mounted directly to the floor, your tank is below floor -- it is sitting up on a platform, you have an above floor tank. If your coach doesn't have a "one-stop" service hatch on the rear, look along, under, and behind the bumper for the dump valve handle. Most of the plumbing will be hidden by the bellypan -- about all that you will see in many cases is the dump valve outlet and the handle. Unless a previous owner has added a gray water tank, your coach will not have one as Airstream did not install gray water tanks in its coaches until the mid 1970s.
Good luck with your project!
Kevin
