Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures
Old 01-18-2021, 02:37 PM   #1
2006 28' International CCD
City , Georgia
Can’t find the hot water mixing valve
My AS is a 2006 28’ International with the Atwood G6A-8E water heater.
I’m chasing an issue with lack of hot water in the shower. Research here shows that this is problem often fixed by replacing the mixing valve at the water tank. I ordered the valve and went to install it today.
I don’t see the valve!! Does my model and year AS not use a mixing valve?
Pics are attached of my tank and piping setup. I’m feeling a bit chagrined and ignorant now.
GotTaGo is offline   Reply With Quote
Old 01-18-2021, 02:42 PM   #2
InsideOut's Avatar
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen , Colorado
Images: 108
I'm not familiar with the specific set-up of your trailer, but generally speaking I thought mixing valves are usually found at the faucet itself - not at the tank. It mixes the hot & cold water closer to the point of contact...
Shari
RMVAC | ACI - CO Unit (Formerly WBCCI) | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 01-18-2021, 02:50 PM   #3
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Do you have good hot water in the kitchen and lav faucets?
GCinSC2 is offline   Reply With Quote
Old 01-18-2021, 05:23 PM   #4
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
That water heater is not equipped with a mixing valve. My 2013 has one, and it is very visible. The three valves shown (which are used for winterizing) are different than what you get when the tank has a mixing valve.
SSquared is offline   Reply With Quote
Old 01-18-2021, 07:30 PM   #5
City , Georgia
Well, I don’t feel so “blind” now not finding the mixing valve. I was just surprised to not have one.
I’m also pretty sure that we had lukewarm water temps at the kitchen sink. What I’m going to do now is to dewinterize tomorrow, crank up the water heater, and determine a baseline of what hot water I have and where it is being dispensed.
Once I do that I may be looking at fixtures and cartridge replacements. What I do know is that we leave for the Florida Keys in 2 weeks and a cold shower is not in my wife’s “glamping” future.
Old 01-18-2021, 07:52 PM   #6
2018 25' International
Slidell , Louisiana
As you learned, older models didn't have a mixing valve and operate with lower temperatures and thus capacities as a result. 130 F is considered the the point where water can scald skin so you should have 130 -140 F water in the tank. Good luck.
Old 01-19-2021, 11:13 AM   #7
JRM
2004 25' Safari
Hernando , Florida
No hot water
Looks like the top and bottom valves are closed keep center valve closed
JRM is offline   Reply With Quote
Old 01-19-2021, 11:19 AM   #8
JRM
2004 25' Safari
Hernando , Florida
No hot water
If top and bottom valve are open close the middle valve
Winterizing, loss of hot water, and the mixing valve. RCC 2018 - Current Globetrotter 8 03-21-2022 06:44 AM
How to remove water heater mixing valve brick1 Water Heaters, Filters & Pumps 1 03-21-2020 12:43 PM
Hot water heater mixing valve lukeysh714 2016 - Current Flying Cloud 1 02-05-2018 12:33 PM
2017 Classic Hot Water Mixing Valve Calibration rivetville 2016 - Current Classic (all lengths) 74 08-17-2017 04:20 AM
Atwood XT Water heater mixing valve orloffgray Plumbing - Systems & Fixtures 0 03-23-2016 07:55 AM
