Old 05-17-2021, 03:50 PM   #1
1973 29' Ambassador
Conway , Arkansas
Broken dump valve
Has anyone experienced a broken handle on an older airstreams black tank dump valve. Just purchased, 1973, with mid bathroom. The handle was gone and the only way I can see to get to it is from the side?
Would I be able to get to this and replace if I dropped the belly pan?
Ambassador73 is offline   Reply With Quote
Old 05-17-2021, 04:35 PM   #2
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I do not know about the 70's trailer. The 80's models the dump valve is under a big galvanized pan that holds the tanks. The way to access the valves is to cut a hole in the galvanized pan and then patch it. That is my suggestion. That is what Airstream does at Jackson Center.
Broken Window AND Broken Plexiglass Rockguard pianolaw Windows & Screens 0 02-16-2020 01:40 PM
Broken jack & broken manual crank handle!! jaybauman Jacks, Stabilizers, Lifting and Leveling 34 07-08-2019 05:10 PM
Broken dump valve Ed Starman Waste Systems, Tanks & Totes 1 05-24-2005 09:02 AM
Dump Valve Will Not Open Darryl Waste Systems, Tanks & Totes 1 06-19-2002 12:19 PM
Dump valve gwsullivan Waste Systems, Tanks & Totes 11 05-30-2002 08:38 AM
