Old 03-29-2023, 07:51 PM   #1
2000 25' Safari
Calgary , Alberta
Black water tank removal
Hi
I have watched some YouTube videos on how to remove a black water tank. Please take a look at the attached photo. Have you ever seen a tank like this? How do I remove it?
Regards
Gunnar
groetschel is offline   Reply With Quote
Old 03-29-2023, 08:15 PM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Not familiar with your particular model, but in most of these trailers that have a black tank sitting on the floor, the only thing holding them in place is the above floor surroundings (which you appear to have already removed), and the dump valve assembly attached to all the ABS plumbing under the trailer. Have you gotten underneath and cut all that piping free?
Old 03-29-2023, 08:30 PM   #3
2000 25' Safari
Calgary , Alberta
evaluate and not destroy
no, not yet. I am currently trying to evaluate and not destroy too much.
Some rivets holding the last two interior panels are behind this black water tank, so I just wanted to get it out of the way. What would you suggest? removing the belly pan first?
Old 03-29-2023, 09:24 PM   #4
Belegedhel's Avatar
Houston , Texas
I guess it depends on what your objective is. A) Are you stripping the entire interior to do a rebuild or replace the floor? Or B) do you not really want to remove the tank, but you need to get at those last rivets?
If A), then I would say you will need to remove the belly pan, banana wraps, tank, etc., anyway, so forge ahead.
If B), then I would recommend getting a long putty knife, and instead of drilling out those pesky hidden rivets, just reach down in there with the putty knife, and tap the handle to shear them off. That being said, it will be impossible to put them back in again....
good luck!
Old 03-29-2023, 10:50 PM   #5
2000 25' Safari
Calgary , Alberta
Thanks for your answer. Really helpful. I think you are right. I am planning to do A) replace sub floor and full rebuild. You are right: belly pan has to go off.
Do you have done this before and some good advice?
Gunnar
Old 03-30-2023, 07:58 AM   #6
Belegedhel's Avatar
Houston , Texas
I have done a complete rebuild of my '73--shell off, floor replacement, insulation and interior skins replaced. I suspect that your 2000 still has a lot in common with the way they were built in the 70's. The floor is (typically) sandwiched between the "base" of the wall and the outriggers of the frame. For this reason, you will have to remove the belly skin and the black wraps around the edge so that you can get to the top and bottoms of the bolts.
When I did mine, I lifted the shell with some homemade wooden gantries, and that worked quite well. There are lots of folks who build bracing inside the shell and jack the shell up against that bracing, but it seems to me that by the time you get all that bracing and jacking done, you could have built the gantries and been done with it. There is also the option to do a shell-on floor replacement, but that has always struck me as the most difficult way to go about it. Do a search for "full monty" "gantry" and "shell-on" and you should find a bunch of threads showing what others have done.
good luck!
New Black Tank thinking about adding a black tank flush Peter417 Waste Systems, Tanks & Totes 1 12-21-2020 11:18 AM
Rust? What rust?? Black tank? What black tank??!? gadgetgeek Repairing/Replacing Floor &/or Frame 2 08-08-2018 11:20 AM
Use Black Water Tank as Aux Fresh Water Tank? DaytonaDan Plumbing - Systems & Fixtures 20 10-26-2016 08:53 AM
Replacing black water tank with grey water tank cheetah1 Sinks, Showers & Toilets 25 10-02-2014 06:26 AM
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 09:35 PM
