I’m installing a Sinkmiser in both my shower and galley sink. I need to connect the water loop to the water inlet. My 30Bunk s’ water inlet is located just above the wheel well completely inaccessible. Aquaview does not recommend connecting a tee at the intake side of the water pump, they said the water will just recirculate becoming hotter and hotter. Any ideas on how to get the water back into the fresh tank? Has anyone installed one of these units?
Hmmm, my showermiser return is tee'ed just upstream of the pump, works as planned. No problems.
-Rich-
It only would keep getting hotter and hotter if you left the lever in bypass. Once you just begin to see the color change, flip the lever off, and it operates just like it does without the miser.
The bonus is you can fill your fresh tank while hooked to city water. Just don't forget and walk away, like I did.
-Rich-
How hard was it to access the plumbing behind the 30 Bunks shower. Wondering if you have to remove the shower or is there an easier way. Love to know the details as we have a tankless heater and it wastes to much water.
You need to remove the white wall, there are 6 or 8 screws. Be prepared to re-calk.
