Old 05-19-2018, 06:46 PM   #1
1970 27' Overlander
Lakeland , Florida
Adding a Grey Tank
I have decided to add a grey tank to my 1970 Overlander. I will have the kitchen sink dran to fitting and then the shower and bath sink into another one. I really want to limit the number holes in the sub-floor. My question is, I know I need to ventilate the tank, can I vent it through the the tub and sink drain pipe or does the vent need its own fitting into the tank?
Hope this makes since.
CraigCam is offline   Reply With Quote
Old 05-19-2018, 07:25 PM   #2
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
Yes, BUT:
The purpose of a vent through the roof in a trailer is:
1. to let air into the tank when the tank drains,
AND
2. to let sewer gas out as the tank is filled,
AND,
3. to keep a vacuum from being created within the pipes that sucks liquids out of the traps.
One vent will suffice, as long as it does all of these things.
However, proper placement of air admittance valves (Google Studor Vent) can make it easier to do with one vent.
Some people say to not combine the black and gray vent, but one vent through the roof will function properly if all of the above conditions are met. Black water and gray water piping should not be connected except at the vent, and that connection should be high in the trailer (at a minimum higher than the sink rim), so that no cross contamination of waste water can occur.
In summary:
The kitchen sink, lavatory sink, and shower waste water piping are all connected to the gray tank. The new vent from the gray tank runs combined with these three fixtures, or use air admittance valves. One gray water vent has to penetrate the roof separately or connect to the existing black tank vent at a level above the sink rim.
The black tank and existing vent function as they exist, except to connect the gray tank vent, if you choose to use the existing vent.
Of course there are many options. You have to choose what you want.
Alan
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
Adding/added a grey tank? rayandre 1970 - 1973 Overlander 3 08-12-2011 09:53 PM
Alternative to adding a grey tank, 60s rig eubank Waste Systems, Tanks & Totes 12 04-06-2011 02:54 PM
Adding a larger grey tank to a 78 Tradewind johnhh Waste Systems, Tanks & Totes 3 04-04-2011 12:43 PM
1963 overlander - adding grey tank? bugdog Waste Systems, Tanks & Totes 11 09-03-2008 04:11 AM
