Old 02-20-2021, 08:42 AM   #1
tarheelbornbred
tarheel1972's Avatar
2010 28' International
1972 29' Ambassador
Hot Springs , North Carolina
Send a message via AIM to tarheel1972
2010 Intl Serenity Shurflow replacement
Replacing the SHURFLO 183-029-14 after a big chunk of ice slid off the roof and karate chopped mine. 2010 Intl Serenity QB 28'
It appears that I will have to do it all from the outside. I HOPE that I can disconnect and reconnect from the outside. As the inside connection is right up against the shower wall.
Does anyone have any intel on this?
Many thanks.
J
John K.
2010 International 28'
1972 Ambassador-retired
2013 Ford F-150 Eco-Boost
tarheel1972 is online now Report Post
John K.
tarheel1972 is offline   Reply With Quote
Old 02-20-2021, 08:54 AM   #2
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Not exactly been there done that but a possible anyway.
Remove the attaching screws and carefully coax the unit away from trailer. The PEX fitting attaches with a "wing nut" type nut.
Bandaid count, maybe two cause of the raw aluminum.
GCinSC2 is offline   Reply With Quote
Old 02-21-2021, 05:18 PM   #3
tarheelbornbred
1972 29' Ambassador
Yep. One of my easier repairs. I was unfamiliar with this chunk of plumbing-ware. But I am now. No bandaids, I do need to make or caulk a good gasket however.
John K.
Old 02-21-2021, 05:32 PM   #4
GCinSC2's Avatar
Good. Always great to avoid bandaids.
I’ve replaced them in two Classics. Looked like I was in a cat fight.
2010 Intl Serenity QB 28' SHURFLO 183-029-14 tarheel1972 2006 - 2010 International 0 02-16-2021 05:30 PM
Shurflow Filter, Up or Down? smsasf Water Heaters, Filters & Pumps 12 11-08-2020 06:09 AM
Shurflow pump does not turn off tim198 Fresh Water Systems 9 08-04-2013 05:04 PM
Shurflow fan shuts down thehiker Roof Vents, Skylights & Fans 2 10-17-2008 04:54 PM
Shurflow 5.7 with chip sensor JimmyJames Water Heaters, Filters & Pumps 5 11-25-2005 06:08 AM
