04-12-2006, 05:49 AM
Massachusetts
Tractor advice needed
With lots of impending landscaping chores this spring and summer, I'm looking to buy a new tractor but there are so many choices and so little time! I'd like to start a thread to get your advice on the best (i.e., reliable) brand/model to look at with the following functionality:
1) Regrade yard to extend driveway
2) Level parts of the yard
3) Create terraced gardens
4) Mow lawn
5) Move snow
6) Pick-up leaves and acorns
7) Dig out tree stumps
8) Rototill gardens
9) Attachment capability for other tools such as cement mixer
As a bonus, I would like it to have a trailer hitch and enough pulling capacity so we could move trailers around the yard as needed.
Am I asking for too much in a single machine?
WBCCI Region One
Attitude is the only difference between ordeal and adventure
04-12-2006, 06:08 AM
1994 21' Sovereign
Down on the corner...
, CT
Sounds like a Bobcat might be on order for you!! We use a 4WD 4-wheeler to get about half of your list completed.
Have to add to this post that you can rent a Bobcat and get a ton of yard work done in a weekend for a fraction of it's cost...that's what we did
04-12-2006, 06:24 AM
Huh?
1975 27' Overlander
Twin Cities
Here's a question I can help with
Yukionna,
The big question is how much do you want to spend.
From the post below you can tell I'm into Fords. And while I think they're the best I wont deprecate any of the other brands/colors.
What ever you buy get one with 3 point hitch!!! That's the gizmo for attaching and lifting your tools/impliments. All the newer brands have it. A lot of the older ones have jury rigged add on 3 point hitch which isn't as good.
Tractor size is measured in horse power. I can not imagine you needing more than about 30 hp to do every thing you mention. Don't let someone sell you some big brute 40-50+ hp. You just don't need that hp and the smaller ones are SO much more nimble and versatile. Buy a wide front tractor not a narrow front. Wide front has lower center of gravity and is much more stable ie. not tippy. My first tractor was an 8N Ford. Built in 1948 it is not just some collectable but a real tractor capable of doing useful work. I'm selling it now because I've upgraded to more modern. 8N Fords are SUCH sweetheart little machines. And they made something like 300 different tools/impliments you can hook to it like snow plows, land plows, discs, back blades, several different types of mowers, front end loaders and the like.
I don't know if you are familiar with all the options on a tractor, like live PTO, power steering, live hydraulics, remotes, etc, etc.
If you needed a tractor with those options then you should look at newer machines like New Holland, John Deere or Kubota. All are very good brands but expect to pay big $ for one. For a first tractor an 8N is ideal and you can pick up a really good running one for under $3000.
I could go on and on but if you are interested in learning more try this site:
www.ytmag.com It is at least as large a site as this one - maybe bigger.
I post on the Ford boards - same name as here.
Happy tractoring,
Jerry
04-12-2006, 06:33 AM
1972 25' Tradewind
Wentworth
, South Dakota
I would agree the New Holland JD or Kabota are very good choices. The 20 hp range with frount wheel assist will do a lot of work. It will handle a 6 foot finishing mower. For serious loader work rent a skid loader.
04-12-2006, 06:41 AM
Just an old timer...
2004 22' Interstate
Tipton
, Iowa
Yuki... take a look at the Honda 5518 tractors. I have an RT5000, the first model of the line. The last was the 5518, an 18hp liquid cooled engine version. They are 4WD, 4 wheel steering, have front and rear power take-offs, front and rear hydraulics, and have a variety of attachments available from several sources now including a 3 point hitch, dozer blade, front end loaders, snowblowers, and several types of mowers. I have a 46" mower deck, and 42" dozer blade and 42" snowblower for my 11HP RT5000. I bought the entire outfit a couple of years ago for $2500 and it was near showroom condition, albeit a 1985 tractor.
They are stone reliable, and won't set you back the $23k that the Massey-Ferguson GC2300 would cost new. The 5518 in excellent condition can be found for around $5k.
Here's a start:
http://www.google.com/search?q=honda+5518
Here's a link to the Massey GC2300: http://www.masseyferguson.com/agco/m...sCare/2300.htm
Roger
havin' to fix my broken Airstreams since 1987...
AIR 2053 Current: 2004 Airstream Interstate "B-Van" T1N DODGE Sprinter
04-12-2006, 07:00 AM
1977 Argosy Minuet 6.7 Metre
Trinity
, Alabama
I agree with Ultradog go to Yesterdays Tactors site it is mostly populated by rural dirt farmer types and they know their tractors. You will find as much or more brand loyalty there as on Airstream site but they can give expert advice on size and type of tractor you need.
04-12-2006, 07:33 AM
The Hawk's Lair
1985 34.5' Airstream 345
BACK WOODS
I currently have two Ford Tractors. One is a 1947 8n that I have had for more than twenty years. It has a loader on the front and a landscape blade on the back. I move snow and grade the driveway with it. The other is an early Jubilee. It was manufactured in 1952 and has seriel # 500. Most folks will tell you that they didn't make them til 53, but they did start the 53 model year in 52. I use it for bush hogging and towing.
These tractors are pretty much "bullet proof". They require very little maintainence and you can get parts all over the place. The best thing is, they appreciate in value over time.
I have a dirt scoop for the three point and also a cement mixer for the three point. Mixes one third yard at a time and you drive to the site, lift the lever to the three point, and it dumps.
AKA THE GUNNER
There is no "I" in the word "team," but there are four in "Platitude Quoting Idiot!"
AIRSTREAM 345 TURBO-DIESEL
VFW, LEGION, NRA
04-12-2006, 08:15 AM
Airstream - Other
Bosque Farms
, New Mexico
Originally Posted by cooperhawk
I currently have two Ford Tractors. One is a 1947 8n that I have had for more than twenty years. ... These tractors are pretty much "bullet proof". They require very little maintainence and you can get parts all over the place. The best thing is, they appreciate in value over time.
I'd have to agree, at least up to a point! Our 47 8N has a broken clutch control arm. As it turns out, the control arm on the 47 differs from the rest of the production years for the 8N. I've been looking for a new (=used) one for weeks now without luck! May have to switch the whole business to one of the later types.
Lynn
ACI Big Red Number 21043
04-12-2006, 08:20 AM
Moderator Emeritus
1972 31' Sovereign
High Springs
John Deere is my recommendation. Yeah, they are expensive. But they have a very extensive dealer network. Only tractor company that has not been sold. In business for over 150 years. A solid American product. Cool colors.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
04-12-2006, 08:28 AM
The Hawk's Lair
BACK WOODS
Lynn
There was or is an old man in Northfield, Mn. who collects and parts out old ford tractors. Last time I drove down there (couple years ago), he had over fifty tractors. I don't have his number but you should be able to look it up. His name is Palmer Fossum. I'll bet he would have the part.
AKA THE GUNNER
VFW, LEGION, NRA
04-12-2006, 08:53 AM
Massachusetts
Wow! I step away from the forum for a few hours and look at all the useful information that pops up! Gotta love this place. You guys are the best!
Someone else mentioned the brand FarmTrac...anyone know anything about that brand?
I also found another tractor forum that bills itself as "The world's largest tractor community"...
http://www.tractorbynet.com/
WBCCI Region One
04-12-2006, 09:17 AM
2004 22' Interstate
Tipton
, Iowa
I live in the middle of all of the Deere plants and I bought a Honda tractor. Deere's lower end tractors have Kawasaki engines and stamped frames... and aren't much above the Simplicity factory offerings... in fact many of them look like they're produced by Simplicity...<sigh> but they do have a good dealer and parts network and a loyal consumer base.
Roger from John Deere country...
04-12-2006, 09:41 AM
DayStreamer
2001 19' Bambi
Mesa
I have used a Ford 8N for a lot of years to do most of my grading & leveling work. I also purchased a small Skid Loader (like a Bobcat) because I needed something with a loader and didn't want to put one on the Ford. However, I found that mountainous/hilly areas are not well suited to the small Skid loader -- its just to tipsy! So, I purchased a small Yanmar 2420 tractor with a box blade and a loader. Yanmar currently builds many of the small John Deere tractors. Mine is a 3 cylinder diesel with 28 hp (more than the Ford's 20hp). The total price came to $6800. This tractor is what's called "Grey Market", meaning that it was built for the Japanese market and brought to the USA as a used tractor. You have to be very careful what you get in a "Grey Market" tractor as some of them you just can't get parts. Others, like the one I got, have parts readilly available and you save 50% over the cost of a comparable John Deere. I still love my Ford 8N but just needed something more versitle.
Dave
DayStreamer
2001 19' Bambi
02 Avalanche
Mesa Arizona
AIR #5591
04-12-2006, 09:58 AM
I have MF 275 for sale in Virginia if interested
I bought it used for $8,800 in 2003 for a year in Virginia before I moved to Minnesota. It has end loader and 6 foot bush hog and 67 HP. It is a diesel tractor with 67 HP. Built in 1980 (according to serial numbers). If interested, call at 507-929-2121. I am willing to sell you $8,000 obo. George. I have pics if you wanted me to email you.
The tractor is parked in a friend's barn in southwest Virginia (south of Roanoke). It would be a day trip for you.
04-12-2006, 10:01 AM
1976 25' Caravanner
Campton
, New Hampshire
Just for information , I don't believe there are any tractors under 40 hp still made in the USA , no matter what the brand . Just another thing we gave away. FWIW , I have an '87 Kabota that I bought new and have not had a single thing go wrong with it .
04-12-2006, 10:50 AM
1984 31' Airstream310
Dunsmuir
I have a 1959 Massey Ferguson TO-35 deluxe which has 35 horsepower, power steering, two stage clutch, three point hitch, remote hydraulics, PTO, and front loader. I paid $2000, plus $1500 to add a auxiliary hydraulic pump for the loader plus various repairs.
It will happily do everything you mention. One question is how much area you will be working with, a skid steer or smaller Kubota, will be more maneuverable in tight spaces.
1984 310 Limited Motorhome
04-12-2006, 11:33 AM
Older Tractor Brakes on a Boat Ramp
I don't want to hijack this thread but the first hand knowledge and experiance round here is too much to pass up.
I 'm thinking about getting a used tractor primarily for launching and retrieving my boats at typical ramps (say 2700 lb. max. at approx. 15 to 20 degree ramps)
What say you about braking adequacy to hold on ramps for a minute or two until I get the wheel chocks in place??
Background motive is to drive a low gas using car (a little car) to the lake (100 miles one way) and keep the tractor there for personal ramp duty. (Might even do some others' boats for cash $$$.)
Will the brakes hold or does the tractor stand a chance of rolling in backwards???
Any comments about engine size etc. etc. are appreciated.
Thanks, Ed
04-12-2006, 11:50 AM
Dunsmuir
Ed,
I'm sure my tractor could do this. I go up and down levees that steep draging logs etc. Depending on the surface of the ramp traction could be an issue. My tractor has fluid filled rear tires so I get very good traction on my ground.
You can flip a tractor over onto it's back if you apply too much power heading up hill with a load behind. I will often back up steep grades.
The parking brakes on my tactor are not so great so you would need one person on the tractor and another person to chock the wheels.
04-12-2006, 12:17 PM
2003 25' Safari
Yakima
I'm happy with the Kubota
I bought a Kubota B7100 hydrostatic 4wd diesel tractor back in '97 and have done everything you have listed. It's something like 16-20hp and can't say that I've ever run outa steam. I've welded up a three-point to 2" receiver attachment and also use it to squeeze the A/S into its cozy parking spot. When I lived in Utah it plowed many a driveway and local street with the bucket or a 5' rear blade. I welded a hook on the back of the bucket and have used it to move railroad ties, truck transmissions and anything else I don't want to wrench my back over. I've used it to tow small airplanes at our family FBO in Montana as well as keeping the ramp clear where the bigger plows couldn't get. I kept my evenings and weekends plenty busy earning beer money doing word-of-mouth jobs, both snow and dirt, for people where they couldn't get a bigger tractor through their gates or didn't want to replace sod when a skid-steer tore it up. I've got a 10kw PTO generator "just in case" and lately have acquired a 4' 3-blade rear PTO finish mower. I pull a 4' box scraper with teeth to tear up old sod or make ready for new yard. And for some odd reason, every time I crank it up and bring it around to grease it or put it on the trailer to take it to a job, my male neighbors seem to use it as a reason to socialize (and ultimately ask if they can drive it!). Honestly, I don't know what some guys do without something like this.
04-12-2006, 02:12 PM
Riverside
, Missouri
I will jump on the 8n bandwagon. I have a 52 8n and love it. I would only purchase one if you are mechanically inclined. Not that they are prone to breaking down, just that it's a 50+ year old machine that needs maintainance. If you can work on it, it can be purchase and maintained for a fraction of the cost of other options and it looks good too. All parts are readily available. WWW.Just8ns.com I even use it to move the Airstream around the property.
