Originally Posted by Jim Keaty
What's the best way to seal the windows. Where is it coming in?
If you find that it is the windows, the most likely culprit is the rubber/metal channel that the windows ride in. There are several threads here on replacing that channel, including this:
http://www.airforums.com/forums/f160...ment-9584.html They include the step of cutting holes in the bottom of the channel adjacent to the weep holes on the outside of the frame. This lets water that collects in the channels drain out instead of collecting and running over into the coach. Even if this step has been followed, the holes that have been cut can collect enough gunk over the years to keep from draining. If you just want it to quit leaking until the rain stops, you might try reopening the holes that you can get to with the window in place.
