Old 05-20-2025, 01:04 PM   #1
92landyacht's Avatar
1992 36' Land Yacht
Grayson , Georgia
Picked up a spare Genset
Since my generator is vital to our usage and since it is now approaching 1000hrs on the clock, I decided to look for a replacement generator just in case. Ended up finding the exact same version of my Onan Marquis 7000 for a great price that only had 15 hours on the clock. It was used as a backup generator for the owner's workshop. He converted it over to 240/120 operation. The other issue was that it was an LP generator.
In the end, I was able to convert it back to 120V only operation and convert it from LP to gas. Cleaned the slip rings, added new OEM carb (Not a Chinese piece of crap) and fuel pump on top of the usual filter and plug changes.
Load tested it to 6900 Watts using space heaters as a load. Should now be a direct drop-in replacement.
Ready to be installed when needed:
New carb and a fuel pressure gauge:
New fuel pump:
Really getting to know how these old guy's work.
92landyacht is offline   Reply With Quote
Old 05-22-2025, 06:35 PM   #2
Airstream Driver
PeterH-350LE's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 49
great find!Curious why you didn't continue to use it on Propane? Much less trouble than gasoline ones. you may sacrifice a little power but you have plenty to spare.
1991 300LE Classic Touring Coach
AIR #13
PeterH-350LE is offline   Reply With Quote
Old 05-22-2025, 07:10 PM   #3
1992 36' Land Yacht
Grayson , Georgia
I only have a 30-gal LP tank on board and that won't last a week of boondocking that I do with running the generator, the fridge, the AC, the hot water heater and heating system if needed. The current generator is gasoline driven so it would be a quick drop in installation this way. No need to run new LP lines. I still have the original LP carb and regulator in case I decide to sell it. That way, any future owner could use it either way.
Spare, spare tire? jondrew55 On The Road... 6 01-03-2022 05:50 PM
Dang, why's my spare tire carrier hanging down? Darn, where's my spare tire? rhensley 2016 - Current Classic (all lengths) 0 10-18-2021 07:17 PM
16" spare tire vs OEM spare tire rack Bluto Wheels, Hubs & Bearings 22 04-30-2013 05:13 AM
Excella 500 Genset uwe 1973-1974 Excella 500 10 06-14-2010 08:58 PM
Creating a spare for the spare easyride Tires 0 06-10-2008 04:16 PM
