I am currently in the process of restoring an 83 310 and am replacing the front cap I have drilled out all rivets on the inside and outside of the window frame, ran a puddy blade around the
outside of the frame and up under rivet holes but the window
frame won't budge that vulkem seems to have it glued in good
I have to get this out in order to get the cap off and I pulled the fridge access door and frame off this weekend and it was difficult
to get out as well but I did manage to get it removed without messing up anything. I have to repair this side window frame as the vertical bar that holds the back of the non slidiing glass (front)
has broken loose at the top and pulled off the glass and the glass is pulled out of the top front corner of the frame.
Also I need to figure out how to get the sliding peice of glass out
of the frame so I won't break it while getting the window frame out any ideas or techniques would be welcomed. I would post some pics for this but don't want to do a play by play as I think most would be bored to death with it. I'll be replaceing the windshields and the front cap and redoing the side windows
