Old 11-19-2020, 03:10 PM   #1
HowieE's Avatar
Princeton , New Jersey
Images: 12
MH degroster heater question
As anyone ever replaced the water control valve for the dashboard/defroster heater in a XL 390 motor home
Freightliner said they did not install it and Arestream draws a blank.
It is forward of the firewall on the drivers side. The hose is leaking at the valve but the trouble it will be to get to it I want to replace the valve at the same time if I can identify it before taking it out.
2004 Excursion 4x4
Old 11-19-2020, 06:23 PM   #2
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
It is probably available from ACME. Regards, Bob
bobmiller1 is offline   Reply With Quote
Old 11-19-2020, 06:26 PM   #3
HowieE's Avatar
Images: 12
It appears Acme has gone out of business.
2004 Excursion 4x4
Old 11-20-2020, 11:28 AM   #4
Magnet18's Avatar
Churubusco , Indiana
http://acmeairparts.com/rvacheaterparts.html#!/Heater-valves-and-Cables/c/16022427
Magnet18 is offline   Reply With Quote
Old 11-20-2020, 11:33 AM   #5
HowieE's Avatar
Images: 12
Originally Posted by Magnet18 View Post
Yes I had found them earlier today just with a dumb Google search. Very helpful when I called.
2004 Excursion 4x4
Water heater/ heater matrix repair montreal Classic Motorhomes 2 06-08-2012 06:00 AM
Propane Heater or Instant water heater valontjej Plumbing - Systems & Fixtures 1 04-09-2012 08:56 PM
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 07:17 AM
Water heater prob, pilot won't stay lit & heater won't fire. johnboy Water Heaters, Filters & Pumps 1 06-20-2006 04:24 PM
water heater and heater cabbage76 Furnaces, Heaters, Fireplaces & Air Conditioning 7 11-12-2003 08:06 PM
