Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > General Motorhome Topics
Old 12-20-2017, 01:24 PM   #1
2017 Interstate Grand Tour Ext
Midwest city , Oklahoma
Main battery
2017 AI ...main battery dead after a couple of days parking. Can’t turn ignition to 2,3 position??? Battery assist does not engage??? Must charge or jump to start...when using shore power doesn’t the inverter charge all batteries?? Main disconnect switch in off mode does not allow me to read tank/battery levels???
Tstidstfm is offline   Reply With Quote
Old 12-20-2017, 05:50 PM   #2
FlyFishinRVr's Avatar
2017 Interstate Lounge Ext
Northern , California
Main battery
Shore power will charge all batteries but only if you turn Main Disconnect ON. In other words the coach power must be ON (red LED in the switch must be ON).
Re. battery assist, you have to hold it down for a bit if your chassis battery is totally dead. The longer you hold it the more it can charge your chassis battery.
FlyFishinRVr is offline   Reply With Quote
1970-1977 Main Door Lock gvanman Doors & Locks 69 09-10-2021 01:02 PM
Need Battery door and bottom vent door on main side Swimhard4 Airstream Classifieds 0 03-09-2015 09:27 AM
Main Propane Ignitor "Element" Cat Furnaces, Heaters, Fireplaces & Air Conditioning 11 05-23-2005 04:28 AM
Main door problems Silvertwinkie Our Community 8 03-02-2003 11:46 PM
1965 Main Door buckmaster 1965 - 1969 Globetrotter 0 10-19-2002 07:47 PM
