Old 02-24-2020, 12:56 PM   #1
2004 30' Land Yacht Gas 30
Rogers , Arkansas
Landyacht Motorhome, leveling pump location/fill
I have a 2004 Landyacht Gas and have noted a pool of ATF under the RV. I think (hope) it is the leveling pump not the transmission. But I can't locate where the pump is how to access it and fill it. It also makes a growling noise when I lower it. Can anyone help me. Also does any one have a source for a new pump, it is a Power Gear model 500456 Airstream part # 410796-01
strad is offline   Reply With Quote
Old 02-25-2020, 07:06 AM   #2
2006 30' Land Yacht 30 SL
Kendalia , Texas
Location
I have a 05, 30 ft and the pump is just to the right of the radiator and has a Power Gear sticker on it
1956elli is offline   Reply With Quote
Old 04-20-2020, 08:45 AM   #3
Mike1997's Avatar
1998 36' Land Yacht Widebody
Shepherdstown , West Virginia
Images: 14
It sounds like the seals in your levelers are bad. While extended my front units would leak. Had both removed and taken to a tractor/farm equipment repair shop. They deal with hydrolic arms regularly. Cost $120 to have both rebuilt. After reinstall and Power Gear box topped off, everything is normal.
Mike1997 is offline   Reply With Quote
Old 04-20-2020, 08:47 AM   #4
Mike1997's Avatar
Images: 14
If your pump itself is bad, I would recommend going to Power Gear or again, a farm equipment shop and let them make a recommendation for similar replacement.
2004 Land yacht Leveling pump location and fill, and leak strad Airstream Motorhome Forums 2 07-06-2020 02:11 PM
'94 Landyacht Motorhome Troubleshooting Water Pump and Generator patsy49 General Repair Forum 1 06-22-2013 07:13 AM
location location location goransons Airstreams on eBay 0 12-05-2009 09:29 AM
Location, Location, Location........... ROBERTSUNRUS Brakes & Brake Controllers 5 08-29-2009 06:13 PM
Location of Auto Fill Valve losbrowns Fresh Water Systems 1 11-12-2007 05:11 PM
