I have a 2004 Landyacht Gas and have noted a pool of ATF under the RV. I think (hope) it is the leveling pump not the transmission. But I can't locate where the pump is how to access it and fill it. It also makes a growling noise when I lower it. Can anyone help me. Also does any one have a source for a new pump, it is a Power Gear model 500456 Airstream part # 410796-01
It sounds like the seals in your levelers are bad. While extended my front units would leak. Had both removed and taken to a tractor/farm equipment repair shop. They deal with hydrolic arms regularly. Cost $120 to have both rebuilt. After reinstall and Power Gear box topped off, everything is normal.
If your pump itself is bad, I would recommend going to Power Gear or again, a farm equipment shop and let them make a recommendation for similar replacement.
