Old 10-30-2020, 09:55 AM   #1
hillier , Ontario
98 30’ land yacht maybe
Hi All OK so I’ve always been just a older trailer airstreamer. Bought and sold and renovated several over the years. Currently considering and close to buying a limited trailer but while searching for a trailerClick image for larger version
ID:	382208 this motorhome has recently caught my eye. However fish out of water as they say - I know nothing of the motorhome line. Would appreciate any insight and advice on this such unit 1998 30’ with 192,000 on it. I don’t know a lot about it yet. Other than he says it’s on a GM workhorse chassis. So other than the obvious things like water leaks or general condition I’m more worried about the mechanics of such a unit. let me have it.
Regards.
kitchy is offline   Reply With Quote
Old 11-02-2020, 05:15 AM   #2
IPM
1996 clipper gas 34'
Blue Springs , Missouri
https://www.airforums.com/forums/f31...rs-216275.html
It's all good
IPM is offline   Reply With Quote
Old 11-02-2020, 05:28 AM   #3
IPM
Fuel pump is in the gas tank. It will fail. Run tank empty, use a sizzors jack to drop tank, and replace pump. Replace fuel lines while there.
Black tank will likely have a mound of poo and wipes in it. Discharge is a horizontal run before a couple turns to out. Worse case disassemble discharge plumbing. Panel unscrews. Unbolt gate valves. Blast away with high pressure. Snaking a hose rigged for high pressure thru the discharge plumbing don't work well due to bends. And the wad of wipes that never dissolves is gonna get stuck anyway. Drive a nail at an angle into a lengthy dowl to dig that out.
Miss my old aluminum body motorhome. Black dump was direct. Better thoughtful design.
It's all good
Air stream 27 land yacht travel trailer rv sair stream 27 land yacht travel trailer r eBay Watch Airstreams on eBay 0 08-06-2011 10:10 AM
Airstream Land Yacht Diesel Repo Slide out Wash/dryer SAirstream Land Yacht Diesel R eBay Watch Airstreams on eBay 0 08-04-2011 07:10 PM
2002 airstream land yacht xc365 s2002 airstream land yacht xc365 eBay Watch Airstreams on eBay 0 07-22-2011 09:10 AM
74 Airstream Overlander Land Yacht F131 Land Yacht eBay Watch Airstreams on eBay 0 04-02-2010 01:50 PM
Maybe a dumb question (maybe not) kamadeca General Interior Topics 11 04-05-2009 02:16 PM
