Old 04-13-2021, 08:12 PM   #1
1961 16' Bambi
Hot Springs , South Dakota
61 bambi stove top vent
There is a space behind the stove top on my 61 Bambi where the warm air from the refrigerator rises. It is surrounded by a decorative grill. There is also a piece of aluminum closing off most of this vent hole. It doesn't look factory but wondering if it is?
Name:	stovetop bambi.jpg
fander is offline   Reply With Quote
Old 04-14-2021, 12:30 AM   #2
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Yep, I believe so. I the late 50’s-early 60’s they did vent into the trailer - usually by a window.
Check out this link for photos of other ‘61 Bambi’s with the same vent.
Shari
RMVAC | ACI - CO Unit (Formerly WBCCI) | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 04-14-2021, 08:12 AM   #3
57Vintage's Avatar
1958 26' Overlander
Battle Ground , Washington
Images: 22
Our 58 Overlander has a vent like that for the oven/broiler, with the exhaust fan directly above. Here's the original configuration:
Name:	Kitchen Sink Cab with Dixie stove.jpg
I enlarged the opening to the width of the stove to make sure heat and moisture from burning propane could be vented easily.
Name:	New sink cab countertop with enlarged oven vent.jpg
The opening in the stove top to the left of the oven vent is original. It lets heat off the back of the stove out. Why it was covered up originally is beyond me.
Harold & Rebecca
Our thread:
https://www.airforums.com/forums/f97...er-172124.html
57Vintage is offline   Reply With Quote
Old 04-14-2021, 04:04 PM   #4
thinktankair's Avatar
1961 16' Bambi
grass valley , California
It looks like you are missing the linoleum that goes in that area. It also looks like they tilted up the metal that goes in that area so nothing fall back there. I have pictures of that area in my blog at my website here under "it's curtains" https://bambiairstream.com/
1961 Bambi
www.bambiairstream.com
thinktankair is offline   Reply With Quote
Old 04-15-2021, 12:26 PM   #5
1961 16' Bambi
Thanks for the picture. That makes more sense than what I have. Do you know of a source for that metal? Different subject but yours lights are different than mine. My fixtures contain a 12 volt and a 110 volt bulb. Mine is from Ohio so maybe they made them different.
Old 04-15-2021, 06:54 PM   #6
PA BAMBI II's Avatar
1964 17' Bambi II
1961 24' Tradewind
Strasburg , Pennsylvania
We have a '61 TradeWind that we are working on right now that has a similar fridge "vent" system. There is space behind the fridge, then a small scoop covering some small holes in the inner skin that then go up through the roof. It also has the gold metal lattice "fence" to keep stuff from falling back into the chasm.
We may not be using the original fixtures (ours has the two-socket fixtures like yours...one for 12V and one for 120V). Also, we may not be reusing the lattice metal.
I was going to try to preserve the aura of the '61 while modernizing a good bit, but in the end, much of the interior and fittings need redone anyway as it is just worn out.
So, my metal lattice and/or fixtures might be available if you are interested.
"The difference between vintage and retro is that vintage is honestly old and cool. Retro tries to be but isn't."
PA BAMBI II is offline   Reply With Quote
Old 04-16-2021, 12:48 PM   #7
1961 16' Bambi
Thanks. I will keep that in mind once I start on that area.
Wanted white enamel top for 3 burner Princess Stove era 1961 Bambi - British Columbia larryr Airstream Classifieds 0 03-27-2021 08:36 PM
Help with our 19' Bambi stove top wando1997 1997 - 2004 Bambi 8 03-12-2016 02:17 PM
Stove top oven vent tweetie1966 LP Gas, Piping, Tanks & Regulators 0 05-04-2015 12:02 PM
is this a vent? I ordered a Stove Vent from Inland and it was not what I needed Martha Roof Vents, Skylights & Fans 5 07-24-2014 04:35 PM
Stove top/vent a hood rebel beck Stoves, Ovens & Microwaves 3 11-10-2005 06:27 AM
