My P30 Transmission is being replaced. The shop wants to replace the radiator as well because the tranny cooling lines go thru it. I am being told that pulling the radiator is very labor intensive. It is to be pulled up thru the hood.
Can anyone tell me the labor time for this? I have searched and not been able to find the time for the 2002 Air Stream Land Yacht 26' with the Workhorse 8.1 gas engine.
Also the shop is having a problem locating new Transmission cooling lines.
any help is appreciated! I need to get back on the road!
I would get a second quote from a reputable shop. Any qualified transmission shop should be able to custom make the cooling lines, using the old ones as a template. Replacing the radiator because of a transmission replacement sounds unnecessary, unless the transmission fluid cooling reservoir is leaking.
1991 300LE Classic Touring Coach
AIR #13
That will be a Allison 1000 5 speed trans. The radiator could be flushed. The external cooler, maybe not. Its a parallel cooler, much harder to flush properly. Also the Allison uses much bigger lines, something like 5/8" or so!
Chris & Brenda....................cMADMAXman
AIR Member 12654
1991 350LE "Zephyr"
1982 310 MoHo (Sold! New home, NYC.)
Many Years ago, 1972 Argosy 24' trailer
Toad, 2001 Chevy Tracker 4x4
Unfortunately the cooling reservoir was leaking. I was hit with a number of other issues...rear main seal leaking, ERG gasket leak, Oil dipstick tube corrosion (I wonder why I had such difficulty getting the dipstick back down the tube). 23 years old and preventive maintenance of belt change and water pump...I decided it was time to look for a newer motorhome as I did not want to put more than $10,000 in repairs. It is a VERY sad decision as I have absolutely loved this Motorhome.
Thank you for your input!
