Old 04-17-2023, 10:43 PM   #1
Renton , Washington
TBI Min idle speed spec info
Looking at the 1994 service manual for 454 TBI under fuel systems (Section 4-4A) the 'Min idle speed' setting is... (Factory set screw) not recommended to adjust.
For the 7,4L auto trans in Drive is 625 (+-25rpm) Closed loop
Controlled Idle Speed is as follows:
454 7.4L in Drive 675 (+- 25rpm) IAC count 5-30 (Closed loop) at operating temp 196-222F (add 2 counts for every 1000ft above sea level
The 'controlled idle speed' is obtained by the control module positioning the IAC valve. A high/low coolant temp or AC clutch engagement may signal the control module to change the IAC counts.
IAC counts will be above 60 if idle is too low and zero counts if idle is too high. Things to check if so...
1. Vacuum leak/s
2. System too rich
3. TB obstruction
4. PCV issue
5. AC issue
1994 Fleetwood Southwind Storm 28ft
VIN#1GBJP37N4R3314754 (454 7.4L TBI w/4L80E)
1972 VW Westy hardtop-2056cc Type-4 Massive
udidwht is offline   Reply With Quote
(ISC) Idle speed control actuator udidwht Mechanics Corner - Engines, Transmission & More... 2 04-20-2023 04:18 PM
1990 454 TBI Very Rough Idle weatherbie Classic Motorhomes 32 03-12-2023 11:16 PM
AC Compressor cycles 2 min on 6 min off justjeff Furnaces, Heaters, Fireplaces & Air Conditioning 6 07-06-2020 07:33 AM
Sprinters: to idle or not to idle? briborg Sprinter and B-van Forum 12 06-04-2007 10:14 AM
Yikes! No Idle Adjustment - Fast Idle. lebolewis Tow Vehicles 97 08-27-2006 05:20 PM
