Old 03-10-2024, 01:43 PM   #1
1999 35' Cutter Bus Diesel Pusher
Circle pines , MN
Starting battery configuration
I have a 1999 cutter Diesel Pusher with three batteries in the rear for starting how do I hook those up correctly to each other
Danfarr is offline   Reply With Quote
Old 03-11-2024, 09:26 AM   #2
92landyacht's Avatar
1992 36' Land Yacht
Grayson , Georgia
Assuming it's a 36V starter system so the batteries would be connected in series with the negative terminal connected to the next batteries positive terminal and so on. Just make sure you get the last negative connected to the frame ground and the first battery positive connected to the starter solenoid. This assumes that the batteries are 12V batteries and your system requires a 36V starting voltage.
92landyacht is offline   Reply With Quote
Parallel Battery Configuration Mack1 Batteries, Univolts, Converters & Inverters 7 02-15-2020 11:31 PM
Lithium battery configuration on a 25" 2017/18 FC twin. n9hox Generators & Solar Power 0 08-27-2017 09:15 AM
1999 cutter battery configuration Fredmarianne Batteries, Univolts, Converters & Inverters 0 06-06-2012 04:22 PM
1978 Interior configuration Aerowrench Member Introductions 1 06-19-2006 10:42 PM
Univolt Configuration rslaymaker Electrical - Systems, Generators, Batteries & Solar 32 02-26-2006 06:50 AM
