Old 02-10-2020, 08:35 AM   #21
1973 Dodge Cayo Motovator
Outbackga's Avatar
Dahlonega , Georgia
Rev the engine to about 1500 rpm in neutral with no load. Listen as the rpm is stabilized. If the knock increases, it may be a rod bearing. If not, something else. This takes a highly tuned ear. More likely a metal on metal knock in another system. A bad rod knock will not go away, so it is probably not that.
Outbackga is offline   Reply With Quote
Old 02-10-2020, 10:23 AM   #22
"Cloudsplitter"
As noted by West Coast Bob...
You have a 'dog house' correct?...take it off, start the engine, put your foot on the brake, step on and off the gas and see how far the engine rolls side to side and listen.
Realizing the engine mounts were probably changed with the swap...I've seen quite a few aftermarket failures.👎
East Coast
Old 02-10-2020, 10:41 AM   #23
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
Tony, how are you doing? I just read through the thread of your September post about going through chemo. Kinda makes the engine knock issue less important.
I hope your treatment was successful and you're on the mend. *Went through this with the DF a few years ago which put us on the Airstream path. Life is short...
Godspeed!
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
jeffmc306 is offline   Reply With Quote
West Knock, Knock... whose there? Mr. Bear. Ray Eklund Boondocking 2 06-12-2014 09:29 AM
"Knock,knock......" "Who's There?" Babeebloos Fun & Games 5 02-18-2008 12:37 PM
Knock, Knock Any body home? Melody Ranch 1966-68 Caravel 4 06-23-2006 05:56 PM
Help severe wind damage tonight jimmieanna Roof 29 03-14-2006 12:25 PM
GM engine knock on startup Silvertwinkie Our Community 35 07-24-2004 07:05 PM
