RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 11-03-2020, 12:03 PM   #1
1984 32.5' Airstream 325
Gainesville , Florida
Need an AC bracket for a 454 bb
Hi folks - well we’re still trying to get our 84 toaster Mh back home after we purchased it a few months back. We got 15 miles up the road and over heated, died(ish) and after a few hours cooling down managed to get to a repair shop. Been there now for 2 months.
After mucha-do, seems there’s a lot of work needed but they re-cored the radiator which has hopefully solved to heating issue. The next problem is a broken AC bracket. It looks as tho’ its been welded before but I’m hoping to send them one to fit directly.... so I can get the beast home
Any ideas where I might find one?
Cheers and thx -
Pete
ID:	382511   Click image for larger version
Shinytoaster is offline   Reply With Quote
Old 11-03-2020, 03:30 PM   #2
Waipio Rim's Avatar
1984 31' Airstream310
Honokaa , Hawaii
Welcome! I think I can see some of the digits of a stamped part number in one of your pictures. If you can get the whole number, try googling it.
Waipio Rim is offline   Reply With Quote
Old 11-03-2020, 07:43 PM   #3
Looks like
Part number stamped - 7950240
No luck so far
Old 11-04-2020, 05:48 AM   #4
No luck so far
I may have one of those. I dismantled a 1986 345 and the one I removed from the engine looks similar to yours. I'll check when I get home tonight.
Old 11-04-2020, 06:15 AM   #5
Thank you!
thanks for looking,- I suspect I’m going to need a few more parts over time.
Old 11-04-2020, 01:10 PM   #6
1971 31' Excella 500
New Braunfels , Texas
454 BB Air Conditioner Brackets
Vintage Air probably has one that will work, if you Google 454 Chevy BB air conditioner bracket, any number of them come up on the search. I have used a/c brackets from Vintage Air for several other engines, and they are very robust and well made.
fordgt40 is offline   Reply With Quote
Old 11-04-2020, 06:29 PM   #7
1991 36' Land Yacht
West Paducah , Kentucky
Is this it?
https://www.ebay.com/i/362974061255?...9a4adbb298d0a5
ronreeder is offline   Reply With Quote
Old 11-04-2020, 07:12 PM   #8
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
Check local junk yards or try sme of these.
http://www.marxrv.com/rvsalvage.htm
Garry
Old 11-04-2020, 09:30 PM   #9
Nope, darn it... thanks for looking tho'
The one I need seems to be a bit unusual/different than the plethora online in that its main plates are spaced a few inches apart... two plates separated by a few inches all in one casting. thanks for looking!!
Old 11-04-2020, 10:16 PM   #10
Magnet18's Avatar
Churubusco , Indiana
Looks more like one of these
https://www.ebay.com/itm/133550243098
https://www.ebay.com/itm/402466781697
Hard to tell if the required holes are in the right place, if they are nothing says it has to be one piece. If nothing else is on that belt can you just zip tie the compressor out of the way to get it home?
1983 Airstream 310 Class A Motorhome
-Rob
Magnet18 is offline   Reply With Quote
Old 11-05-2020, 01:54 PM   #11
My apologies, I forgot to look last night. It was a rough day at work and it totally slipped my mind by the time I got home. I WILL check tonight.
Old 11-05-2020, 01:56 PM   #12
The one I have is cast aluminum which I believe is what GM switched to in the early 80s. My 84 had cast aluminum but my 74 had cast iron.
Old 11-05-2020, 05:19 PM   #13
Sorry, mine is different. Part # C4284.1
The 86 motor it came from had the hybrid v-belt for the power steering, AC pump, water pump and crank. It used a serpentine belt for the alternator, smog pump, water pump and crank.
Old 11-06-2020, 07:36 AM   #14
Not quite the same as mine but it's possible the brackets are now welded steal rather than an alloy casting. A bit hard to see (pg 70 of the catalogue) but I'll follow up and see what they say - thanks for the heads up.
Anyone think this is an Airstream special part or a common bracket?
Old 11-06-2020, 07:53 AM   #15
Thanks for taking a look, I certainly appreciate it. These cast items are few an far between on the web, but it's possible the newer, or repro, versions are welds steel rather than cast alloy.
Next steps when I get her home is fix the AC systems, floor... tho' I have a feeling this is going to be a big job.
This might seem a bit over the top (I'm beginning to think so) but we're selling our place in a lovely gated subdivision with a rather strict housing association.. that said 'no way' to building a garage for the shinytoaster. We have 2 area and no once could have seem the back of the property (the layout) - but apparently the precedent risk was too much.
So, brought a house down the road.. not as nice but has 5 acres and no HA... buried in the forest as well So, saving pennies to build a workshop for the cars and toaster...where no one can say my lawn is an inch above regulation....
Cheers-
Pete
Attachment 382626
Attachment 382627
Attachment 382628
Old 11-06-2020, 02:58 PM   #16
Magnet18's Avatar
Cheers-
Pete
I bought a place the next county over to avoid pesky rules
Hope it works out for you!
Old 11-09-2020, 11:25 AM   #17
Airstream Driver
PeterH-350LE's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 51
Cheers-
Pete
Good move, you will not regret it. When we were looking to move 10 years ago, the criteria was a shop and plenty of room for the Aluminum. I lucked out, it even came with a nice house
AIR #13
PeterH-350LE is offline   Reply With Quote
Late 454 vs early 454 & 400 vs 4L80E gbell Mechanics Corner - Engines, Transmission & More... 33 07-01-2017 06:59 AM
Need Curtain Rod Mounting Bracket perryg114 Upholstery, Blinds, Walls & Interior Finishes 1 06-25-2012 05:17 AM
I need a picture of the awning hinge/bracket DougZ Awnings 8 10-23-2011 02:32 AM
need a180 degree bracket for cat heater? ashe Furnaces, Heaters, Fireplaces & Air Conditioning 2 11-07-2010 09:45 AM
need fan bracket housebg Roof Vents, Skylights & Fans 5 06-02-2008 07:41 PM
