Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 11-14-2007, 05:54 PM   #1
TorpedoFamily
Torpedo Family's Avatar
2014 30' Classic
Ozark , Alabama
MoHo 36 Land Yacht 2001
Have two problems, one is the heater core, Acme Manufactured, anyone replaced on of these?
My engin block heater shorted. When I checked the plug installed to the wall switch found the switch installed UPSIDE DOWN. OFF was ON...no wonder it failed, it has been running for six years. You may want to check yours!!
Torpedo Family is offline   Reply With Quote
Old 12-04-2007, 07:33 PM   #2
Robfike's Avatar
2012 31' Classic
1999 36' Land Yacht Widebody
Andalusia , Alabama
I had to have mine repaired. I was in the A/C-heater unit for another problem and found the core had a small leak.
My coach is an '86 345. On it the heater core access is good, and the core slides right out. The A/C-heater unit is behind the carpeted panel in front of the copilot seat.
I can give you more detailed info if needed.
Rob
Robfike is offline   Reply With Quote
2001 bambi 19 values? floodbucket 1997 - 2004 Bambi 4 06-12-2020 08:46 AM
AS Wannabees: 2001 Safari 25 SS ??? Garfield Member Introductions 4 10-08-2007 10:23 PM
New TV for my 2001 Bambi geosouth 1997 - 2004 Bambi 4 02-13-2006 11:28 AM
Towing with a 2001 VW Eurovan MV.... crazylev Tow Vehicles 23 02-07-2003 10:35 PM
