Old 03-28-2023, 07:03 PM   #1
Renton , Washington
(ISC) Idle speed control actuator
Figured I bring this to folks attention since it's often referred to incorrectly or even unknown by many. For the older TBI engines (454) there is a vacuum can attached to the throttle cable on the drivers side of the TBI.
This vacuum can is the 'Idle speed control actuator' aka as 'Throttle kicker'.
It serves a few purposes...
As for the 'Idle speed control actuator' it was not installed in all models of GM. I believe only in the truck models such as the P-30 chassis. It is the vacuum can on drivers side of TBI attached to throttle cable. It has a vacuum line running to the 'EGR valve control solenoid' which is on the passenger side of the TBI just forward of it attached to a bracket.
See pic of mine for aforementioned items: https://www.dropbox.com/s/ow3nt7k4hf...B1%5D.jpg?dl=0
Idle Speed/Throttle Actuator - Mechanical: Description and Operation
Purpose: The idle speed control actuator system assists the idle air control system in controlling the idle speed, primarily at cold temperatures.
Operation: The idle speed control actuator is a vacuum operated device which opens the throttle slightly (2 to 3 degrees of angle) to increase the cold engine idle speed, to improve the mixing of the air and fuel, and to allow lower warmed up engine idle speeds. The idle speed control actuator is controlled by the EGR valve control solenoid, which is controlled by the power control module. To increase the idle speed, the EGR valve solenoid is turned "OFF," and no vacuum is routed to the idle speed control actuator, allowing it to open the throttle slightly. To decrease the idle speed, the solenoid is turned "ON" and vacuum is routed through the solenoid to the idle speed control actuator, allowing the throttle to fully close.
In conjunction with the idle speed control actuator system, the idle air control continuously monitors and controls the engine idle speed to the desired idle speed. A Tech 1 scan tool will read the control module commands to the idle speed control actuator system.
The throttle actuator provides another function. The larger the TB, the more the bores expand as the engine gets hot. The 92+ 454 equipped truck ran much hotter than the older square body version. And GM had switched to a heated intake instead of the small heater plate, which was much more effective at heating the TB and keeping it warm after the engine was shut off. Well, a larger bore means the throttle plate must be closed more to keep idle speed low. No problem, right? Just reduce minimum air by turning the throttle stop and you're done. But if you do that when the engine's hot, the next day when you go to press on the accelerator while the engine's cold, the throttle plate is stuck. Not so good. The throttle actuator allowed a way to reduce idle speed when hot yet keep the throttle far enough open when the engine was off so a cooling TB wouldn't seize the plate.
The following is the correct OBD-1 code chart for the early 90-95 years: https://www.troublecodes.net/gm/#codesobd1
As for the adjustment of the 'Idle speed control actuator' (Vacuum can) aka throttle kicker...
Idle Speed Control Actuator Adjustment
Procedure: (from manual)
Before adjusting ISC actuator you must first check the minimum idle speed to be within specifications. Refer to SPECIFICATIONS/IDLE SPEED. (ISC actuator must have vacuum applied so that it is not contacting the throttle lever.) See image VIEW A.
Remove vacuum hose on ISC actuator on warm engine.
Adjust ISC actuated idle speed to 1300 +/- 50 rpm. See image VIEW B.
Install vacuum hose.
In the even the vacuum can is leaking and not holding vacuum and you're unable to source another. You'll need to get at the 'Idle adjustment screw' that is covered by GM on the front side of the TBI. Turn it open roughly 1 turn. This will open the throttle blade slightly. The IAC will/should make up the difference.
In the event the vacuum can is leaking and not holding vacuum and you're unable to source another. You'll need to get at the 'Idle adjustment screw' that is covered by GM on the front side of the TBI. Turn it open roughly 1 turn. This will open the throttle blade slightly. The IAC will/should make up the difference.
Prior to doing this you must make certain that the min idle speed is set first.
1994 Fleetwood Southwind Storm 28ft
VIN#1GBJP37N4R3314754 (454 7.4L TBI w/4L80E)
1972 VW Westy hardtop-2056cc Type-4 Massive
udidwht is offline   Reply With Quote
Old 03-28-2023, 07:47 PM   #2
Renton , Washington
454 7.4L TBI min idle adjustment
Following is from 1994 service manual (454 TBI)
As for 'Min idle speed adjustment'...the 'Idle set screw is covered by GM from the factory. But in the event you have a TBI that has had the screw messed with the adjustment is as follows...
First as for the spec on 'min idle speed' it is as follows for the 7.4L TBI"
625rpm (+/-25rpm) trans in 'Drive' at normal operating temp-closed loop 195-220. And IAC closed (seated). And be sure the 'Idle control speed actuator is not holding throttle lever open.
This is once you're certain you have no vacuum leak/s.
Now the 'controlled idle speed' spec is:
675rpm (+/- 25rpm) trans in 'Drive' with IAC counts in the range of 5-30. Add 2 IAC counts for every 1000ft & up elevation. Normal operating temp closed loop 195-220.
To reset the IAC:
1. Disconnect battery for 10 seconds then reconnect
2. Key On but engine Off for 5 seconds
3. Ignition Off for 10 seconds
A high idle would be one over 800rpm with IAC fully extended (closed). Look for vacuum leak/s. Also check fuel pressure. TBI years 94-95 had fuel pressure of 26-32psi. Previous year TBis were 9-13psi.
Service manuals here:
https://www.gmt400.com/threads/88-98...manuals.43575/
Old 04-20-2023, 04:18 PM   #3
Boom Sounds's Avatar
1991 25' Airstream 250
Oxford , Oxfordshire
My 91 doesn’t have the vacuum can.
Suggest you buy the ADLD droid Bluetooth dongle if you are running OBD1 and the TBI/4L80E and don’t already have it.
Also buy the parts and illustration manuals to supplement the other Chevy factory manuals do that you can distinguish the P32 Motorhome stuff from the P3/P30 series options
Boom Sounds is offline   Reply With Quote
Allison AT540 (4-speed) swap to 5-speed Jeremy Krug Mechanics Corner - Engines, Transmission & More... 0 07-21-2021 06:07 PM
Dexter E/H Actuator to replace ActiBrake Actuator nickmeloy Brakes & Brake Controllers 32 10-22-2014 08:58 AM
Sprinters: to idle or not to idle? briborg Sprinter and B-van Forum 12 06-04-2007 10:14 AM
Yikes! No Idle Adjustment - Fast Idle. lebolewis Tow Vehicles 97 08-27-2006 05:20 PM
2 speed wiper switch has no low speed rdm Mechanics Corner - Engines, Transmission & More... 6 01-09-2003 08:47 PM
