02-06-2021, 08:53 AM
#101
manchaca
Great that you found an answer. Can you keep us informed over the next few weeks or so, so that we can find out how the starting fix works? It would be good hear about hot and cold starting and if the MAP fixed everything!!
02-06-2021, 01:33 PM
#102
Airstream Driver
1994 30' Excella
1992 35' Airstream 350
Austin
sure will, it has been consistently starting and the injectors are firing as intended since I replace the MAP sensor.
AIR #13
02-06-2021, 01:50 PM
#103
Airstream Driver
1994 30' Excella
Austin
The lower pressure Walpro-GSL395 arrived and I installed it today. The higher pressures GSL392, I purchased as a spare, sold within hours on Ebay. My plan is to keep the one I removed as a spare.
When I checked the number on the one i removed it said GSL-395, what a surprise. So Brad gave me the correct number after all, and i screwed up when I purchased a spare. Just please don't tell Brad, I will never hear the end of this, ever!
The puzzling thing of course is why did I get 40PSI line pressure when I connected the fuel pressure gauge ? It may be best to leave good enough alone and enjoy a beautiful cold start.
AIR #13
02-07-2021, 06:28 AM
#104
1991 25' Airstream 250
Oxford
, Oxfordshire
Originally Posted by PeterH-350LE
. When I checked the number on the one i removed it said GSL-395, what a surprise.
Hi Peter - was GSL-395 marked on the pump you removed from inside the tank or were you replacing an old external pump which carried that marking?
02-07-2021, 06:56 AM
#105
Airstream Driver
1994 30' Excella
Austin
The external fuel pump, I installed a year ago is a Walpro GSL-395
AIR #13
02-07-2021, 09:55 AM
#106
Richmond
, Kentucky
So, I'm not quite as senile as I've been thinking I am....
Makes me wonder if the pump always put out 40 psi. What pressure is the new pump providing?
1975 24' Argosy Motor Home
02-07-2021, 10:26 AM
#107
Churubusco
, Indiana
Peter and I talked about that last night. My guess is it was 40 psi since it wasn't connected to a regulator, the fuel line was plugged by the gauge. Probably rated for 15psi continuous when regulated, if plugged it will build up to 40, but probably burn out if left like that
02-07-2021, 10:57 AM
#108
1992 36' Land Yacht
Grayson
, Georgia
The only way to accurately read fuel pressure is to have the gauge T-ed in line with the input to the throttle body. The regulator in the throttle body will keep the fuel pressure constant and the remaining fuel will be returned to the tank. By terminating the fuel line with the gauge you're seeing more pressure than would be normal.
02-07-2021, 11:10 AM
#109
Airstream Driver
1994 30' Excella
Austin
Thanks, that answers that question.
I just finished rebuilding the throttle body, including new injectors. Installing the pressure regulator diaphragm is a tricky job with so much pressure on the internal spring. Also found a open vacuum port in the front of the throttle body. I am almost certain the IAC (Idle Air valve) on the throttle body was not working properly either.
Summary, IAC, TPS (replaced that earlier) and MAP sensor all were defective.
I want to sincerely thank everyone who made a contribution trying to find the cause of my cold start issue. I learned a tremendous amount about the TBI Model 220 used in the early 90's
AIR #13
02-07-2021, 12:22 PM
#110
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim
, New York
Well.......now that you have replaced everything you should be good to go,for a while ! LOL, Regards, Bob
02-07-2021, 01:00 PM
#111
Airstream Driver
1994 30' Excella
Austin
I am just copying you, Bob
AIR #13
02-08-2021, 04:54 AM
#112
Airstream Driver
1994 30' Excella
Austin
I just finished rebuilding the throttle body, including new injectors......
A pretty complete video about rebuilding the throttle body. Only thing I would add, is to be careful using a razor blade cleaning up the old gasket and I recommend using thread lock and an inch/pound torque wrench to set the screws.
AIR #13
02-09-2021, 09:13 AM
#113
Richmond
, Kentucky
Peter, do you have a permanently installed fuel pressure gauge now?
02-09-2021, 04:02 PM
#114
Airstream Driver
1994 30' Excella
Austin
Not yet, I just received the inline adapter for the sending unit I need to install. I almost ordered the wrong 100 psi gauge in the beginning of this saga.
AIR #13
02-10-2021, 09:22 AM
#115
Richmond
, Kentucky
What gauge did you order?
02-10-2021, 09:37 AM
#116
Airstream Driver
1994 30' Excella
Austin
Have not ordered it yet. No VDO's in black to match mine. Any suggestions for 2 " non mechanical?
AIR #13
02-10-2021, 10:59 AM
#117
Richmond
, Kentucky
I ended up with this Maxtow 100 PSI fuel pressure gauge. I couldn't find anything less than that. My guess is most systems now run higher fuel pressures so a 100 psi gauge makes sense.
02-11-2021, 01:50 PM
#118
Airstream Driver
1994 30' Excella
Austin
Update #36 on the cold start issue:
Engine sat for 2 days, temp right at 32F, fired up on the first crank!
Isn't it nice if a fix actually works more than once
AIR #13
02-15-2021, 07:52 AM
#119
Airstream Driver
1994 30' Excella
Austin
10F this am, started on first crank. I think I got it.
AIR #13
