04-16-2019, 02:03 PM
2018 28' Flying Cloud
Mahomet
best small air compressor
Just trashed my small air compressor, one I carried around on the road to inflate tires, blow out lines when winterizing. So now I'm hoping to get good recommendations for a good compressor, one which would do those tasks without taking all afternoon to inflate a tire. Light weight and compact would be ideal, but powerful enough to do the basics efficiently. Good ideas?
04-16-2019, 02:07 PM
2016 25' Flying Cloud
Jupiter
We like our Viair portable air compressor. They make some different models depending on what you need and how much you want to spend. We got this one: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
"A good traveler has no fixed plans, and is not intent on arriving." - Lao Tzu
04-16-2019, 02:38 PM
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
Not the smallest, but this is what I use. It's not just an air compressor, but it's also a jump starter, and it has both a 12v power outlet and a USB port, and has a small LED work light attached so you can see what you're doing at night. Having an air compressor that doesn't have to be plugged in while airing up a tire offers increased utility as well.
04-16-2019, 03:19 PM
Tampa
I bought the Viair 400P-RV kit.
It's the pump that provides more air than the 450, but cannot run continuously. It's never been a problem.
In all honesty, save yourself some money and don't buy the full blown kit. Two hoses? With the Airstream you can reach all the tires with one hose, and the times I've connected two they turned into a tangled mess I gave up on. Also, the kit comes with a 12" long air chuck. I've never used it. I love the gauge and trigger.
So, the unit that checks all the boxes, IMO, is the Viair 400-P (not RV)and it almost $100 less on Amazon.
04-16-2019, 03:51 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
A 'portable'(Vair), pump is not a compressor, there is no tank to hold the compressed air. I have one to take on the road, but use a compressor at home for winterizing.
A pancake would be a good option for Winterizing at home, patience necessary it's a slow process. If you have a generator it is an on the road option.
I used a Black & Decker AC powered fo years on the road.👍
04-16-2019, 05:30 PM
From All Over
Thank you. Nomenclature is important. I do have a compressor that I keep at home, that I can use for winterizing. But the pump/jump starter is what I carry on the road.
04-16-2019, 06:50 PM
Jupiter
This thread is about 12V DC air compressors, that need to run continuously to inflate an object like a tire or sports ball, not the typically much larger AC driven air compressors that include a pressure vessel to accumulate compressed air. Even a manual hand bike pump compresses air.
04-16-2019, 07:25 PM
From All Over
While nomenclature is important, there's no need to get pedantic about it. "Air pump vs. compressor" doesn't need to go the same route as the recurring "propane tank vs. cylinder." For the sake of our collective sanity, let's just say a compressor has a tank ( and a pump to fill the tank) and a pump by itself doesn't have an attached tank.
04-16-2019, 07:28 PM
2020 Classic 33
Box Elder
, South Dakota
I've used the ViAir to do the blowouts in the winter. Added an inline pressure regulator to regulate to 55#'s or so and have had no issues. Becomes more of two person job, one opening the various water valves the other triggering the air, but I have done it by myself.
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NØVPN
04-17-2019, 09:33 AM
2012 25' Flying Cloud
Berlin
, Maryland
Agree with Molly Dad's The Air
04-17-2019, 10:24 AM
2018 27' Globetrotter
Apollo Beach
I had a couple different 12V air pumps that took forever to fill 80 PSI tires. This one from Home Depot was complete junk: https://www.homedepot.com/p/Husky-12...D12A/301753171
Now I carry a $99 150-PSI Porter-Cable pancake compressor powered by my generator which can easily adjust my 80-PSI tire pressures:
https://www.homedepot.com/p/Porter-C...2002/203162815
2021 Northern-Lite 10-2 & F350 DRW PSD, 600W Solar/Victron/600A BattleBorn
146 nights 31,000 miles (first 10 months!)
Sold: 2018 GT27Q, 74 nights 12,777 miles
Sold: 2017 FC25FB, 316 nights 40,150 miles
Sold: 2013 Casita SD17 89 nights 16,200 miles
04-17-2019, 10:27 AM
The Tin Man
2017 27' International
SoCal
+1 for the Viair 400-P
2017 Serenity 27FB
Registry Name
"Rivets for the Tin Man"
WBCC #4913
04-17-2019, 10:31 AM
2015 27' Flying Cloud
Newberg
, Oregon
Viair. They work great.
Mike
2015 27ft FC FB
WBCCI #3960
2019 F150 ecoboost
04-17-2019, 11:28 AM
Caledonia
, Michigan
I got tiered of burning out my compressors, so I upgraded to the Dewalt 60VMax battery powered 2.5 gallon unit (DCC2560T1). It's bigger than the other portable options, but it works well. I'm hoping it will last a while. It's expensive, once you buy the unit, batteries, hose and attachments.
https://www.dewalt.com/products/gear...-kit/dcc2560t1
04-17-2019, 12:16 PM
Tampa
I carried a pancake type air compressor when I had the motorhome with unlimited storage.
But, for the AS, the Viair 400-P has been good, and requires much less space.
As far as "compressor", if the device did not compress the air, it couldn't force more air into half inflated tires. The piston takes air from outside and compresses it to what is needed to enter the tires.
If my AS tires need 10 pounds after sitting, it probably takes 3 minutes to accomplish that. That's why I don't worry about continuous use.
Nit Pik: Who designed the Viair hoses? First, why they don't use the common air hose quick release is a mystery.
If you buy the kit with two hoses, they are not the same!
(due to the compressor and gauge BOTH having male air fittings.)
One is the master and the second is an extension! Not interchangeable!
They are so coily/springy (is that an adjective?) that if you be so foolish to try putting the two together it springs into a tangle. It's a two person job to keep them separate!
[/rant] I'd buy the Viair again even with warts.
04-17-2019, 12:45 PM
2018 26' Flying Cloud
Oriental
, North Carolina
ViAir for me. Yes, they are not perfect, but it does a great job.
04-17-2019, 02:33 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
"An air compressor is a device that converts power (using an electric motor, diesel or gasoline engine, etc.) into potential energy stored in pressurized air (i.e., compressed air). ... An air compressor must be differentiated from a pump because it works for any gas/air, while pumps work on a liquid."
See everyones wrong.🤓
... sir, how much is the bike compressor in the window?😂
04-17-2019, 03:04 PM
Married with Airstream
2004 25' International CCD
Vancouver Island
, British Columbia
IMO you want to go with:
Viair 40047 400P-RV Automatic Portable Compressor Kit + VIAIR 90145 RV Winterization Kit - bottom line is you get what you pay for.
La Dolce Vita Brick & Mona
We're Married With Airstream dot com
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD FX4 SuperCrew Lariart (MaxTow) "Red Dragon"
04-17-2019, 03:46 PM
2017 25' Flying Cloud
Dallas
I keep a 2 gallon Kobalt compressor in the bed of my truck. If you have a Ford, you can run it using the factory inverter. This make short work of floats, air tools, 80 psi tires and most other light uses.
https://www.lowes.com/pd/Kobalt-QUIE...sor/1000405185
2017 25FB Flying Cloud
2022 Ford F-350 Platinum FX4
"Life is a team sport"
