07-20-2008, 01:38 PM
1984 27' Airstream 270
long beach
airbags
I have 1984 excella 270 and air bags in rear don't hold air. where can I find replacements?
08-05-2008, 07:23 PM
1979 28' Airstream Excella 28
Jemez Springs
I have a 1979 Excella and also need new air bags. (In New Mexico, though mail order is fine.) Chipmunks love to eat them...
Is there an FAQ with links to appropriate Parts Houses?
08-05-2008, 08:27 PM
1984 31' Airstream310
Ajo
How do you know it's the bags,are you on the frame? There are other things that could
be happening.
08-06-2008, 10:08 AM
Dunsmuir
Assuming you are referring to the rear air bags, there is a sticky thread on the topic in this forum. Go to the forum thread list, I think it is the second thread.
If you want others to be happy, practice compassion.
If you want to be happy, practice compassion - The Dalai Lama
1984 310 Limited Motorhome
Courtesy Parking (W/S/E/Wi-Fi) on I-5 in Northern California, 70 miles from Oregon border
08-11-2008, 09:16 PM
long beach
airbags
Surprise!! I crawled under motor home to check out fuel problem and found bags to be holding air! Now need just to replace airlines from pump to tank.
08-12-2008, 07:20 AM
Richmond
, Kentucky
ixnaycraig,
Be extra careful when working under the rear while working on the airbags, airlines, valves etc. You need to put jack stands under the rear frame so that if you bump the air leveling valve, break an airline or something simliar the back end of the motorhome won't fall on you. Better to be safe than sorry .
1975 24' Argosy Motor Home
09-30-2008, 02:50 PM
1989 34.5' Airstream 345
waynesboro
if anyone still needs airbags, check out a few of my threads... i found replacements. They have worked good so far as long as yours are the same sizes.
1989 345LE
10-30-2008, 08:00 PM
1982 28' Airstream 280
Elkmont
I took off the airbag system and put on leaf springs.
11-03-2008, 06:09 PM
long beach
airbags
My airbags to hold air I think the problem is the line from the pump to the bags. THe axle has space from the bump stop.
11-08-2008, 10:38 AM
Silver Bullet
1986 34.5' Airstream 345
choctaw
, Oklahoma
I found a cracked fitting at the check valve on my 'Silver Bullet'. A spray bottle of soapy water and body flexibility. Darn hard on a old fat man to get down into that corner where the pump is. I could see it or I could touch it, but not both.
choctaw mel
11-11-2008, 02:03 PM
waynesboro
Mine had space from the bump stop with no air in the bags, you should be able to hear the bags leaking if that is the problem, and if your line leaks bad enough as well shouldn't you be able to hear this as well?? You should have lines running in on each side of the bags, if its set up like mine.
1989 345LE
