Old 07-21-2020, 06:42 PM   #1
1994 33' Land Yacht
APEX , NC
94 Land Yacht AC compressor search
I am attempting to get the coach AC running. It was converted to R134a some time ago, but by the time she came to me, the compressor was GONE. No numbers, no hints.
Anyone have a clue where to begin? It's a 454 Chevy engine but I cant locate any information
Thanks.
RON NICKELS is offline   Reply With Quote
Old 07-21-2020, 07:07 PM   #2
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
R134a was mandated in 1992, so it wasn't converted.
Most of the factory installs had R4 compressors. If so, they are pretty common, and still relatively cheap. If you find a replacement, make sure you replace the drier and orifice tube along with the compressor.
Old 07-21-2020, 07:36 PM   #3
Airstream Driver
PeterH-Airstreamer's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 51
Is the bracket still in place?
My 1992 350 was converted to 134A in 2001 and this was the compressor I just replaced with the identical one. Some $200 plus
1992 350LE Classic Motorhome
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 07-22-2020, 06:40 AM   #4
1994 33' Land Yacht
APEX , NC
94 land yacht ac compressor. MIA
The bracket is still there. the bolts run in parallel to the compressor housing and there is an H shaped single bolt clamp that clamps both the lines in.
Old 07-22-2020, 07:00 AM   #5
Airstream Driver
1994 30' Excella
Images: 51
Lucky you, the bracket could be harder to find than the compressor. Take a good picture or two of the bracket and location of Hi/lo lines and will try to compare. I can also give you the belt size required. Its Gates 7603 for my application (main belt is serpentine, small powersteering belt and this bigger one )
AIR #13
Old 07-22-2020, 10:43 AM   #6
1994 33' Land Yacht
APEX , NC
94 as ac bracket
Old 07-22-2020, 05:04 PM   #7
1994 33' Land Yacht
APEX , NC
I hope these photos go through...
ID:	373687   Click image for larger version
Old 07-22-2020, 06:29 PM   #8
Airstream Driver
1994 30' Excella
Images: 51
Ron, here are some pictures for you to compare. Bracket and adjuster looks like its the same. you are missing the Hi/lo connections/charge ports . Who ever took the old compressor out, must have left them on the compressor. Dont you hate when they do that.
It appears that the loose connector (green/black) is the clutch wire. Green to red clutch wire and black to ground
ID:	373700   Click image for larger version
AIR #13
Old 07-23-2020, 09:53 AM   #9
You might get lucky and find the needed hose and pump fittings at Nostalgic Air.
Old 07-30-2020, 01:52 AM   #10
Boom Sounds's Avatar
1991 25' Airstream 250
Oxford , Oxfordshire
Try having a look at the old service manuals here:
https://www.gmt400.com/threads/88-95...manuals.43575/
Perhaps another owner can look up their AC number on a similar year coach
I believe the Sanden SD-7H15 was used in some of these coaches. My 91 had a Diesel Kiki and it has a red sticker on it which says 488-23075. Richard at ACME might be able to provide some advice on your set up.
http://acmeairparts.com/compressorsseltec.html
https://atc.ca/product-lines/atc/a-c-compressors/
http://www.acpartsguys.com/tech_tips
Good cross ref guide also attached!
Good luck
Nick
Boom Sounds is offline   Reply With Quote
Old 08-08-2020, 09:53 AM   #11
1994 33' Land Yacht
APEX , NC
found the compressor
Thanks for your suggestions. The Chassis is a Chevy P30. Sanden works.
Limited Edition Airstream Land Yacht Clipper Bus Search/Rally frankandsue Forum Rallies & Meet Ups 0 09-18-2010 07:45 AM
73 Land Yacht needs a new compressor lexusparts Furnaces, Heaters, Fireplaces & Air Conditioning 4 03-14-2009 08:54 AM
Search - Where did SEARCH Go? Foiled Again Forum Admin, News and Member Account Info 4 10-16-2005 09:49 PM
