Old 02-06-2023, 04:57 PM   #1
1982 31' Airstream 310
henderson , NV
82 310 turbo diesel
I'm having to replace the fuse panel in the dash of an 82 airstream motorhome i couldn't find an exact match to the original i found one very close through summit racing. I took the old panel and removed the clips and replaced them to match the same slots in the new one. There are wires that splice a dozen times and not like factory in line fuses like someone messing up. The taps i replaced the ones that existed. I have no power at all now and I can't find any kind of diagram that tells me what the wires coming through the firewall into the fuse panel are and what they need to connect to. I feel i bit off more than i can chew and i really want to get this working for my customer. Thanks all
ID:	427847   Click image for larger version
ID:	427849   Click image for larger version
Rubberducky is offline   Reply With Quote
Old 02-07-2023, 08:19 AM   #2
Yep, typical Airstream wiring. What makes things worse is the older the Airstream the more people that have fiddled with the wiring.
Your best bet is to find a GM chassis manual for an 81 or 82 P30. I believe the wiring should be typical for GM vehicles of the era. Even a 1-ton pickup manual should get you close.
Unfortunately for you this task is going to be difficult because Airstream didn't do a very good job of documenting their additions to the wiring.
If it was me, I would tackle getting the chassis components to work first and then delve into the Airstream wiring.
Good luck.
1975 24' Argosy Motor Home
Old 02-07-2023, 10:50 AM   #3
dadstoy's Avatar
_ , _
These aren't for the diesel, but they might help...
ID:	427870   Click image for larger version
ID:	427872   Click image for larger version
To chase the dragonfly is to chase the wisdom of the world
dadstoy is offline   Reply With Quote
Old 02-09-2023, 07:11 AM   #4
92landyacht's Avatar
1992 36' Land Yacht
Grayson , Georgia
Hope your "customer" isn't reading this.
Good luck getting things running again. What was the original problem?
92landyacht is offline   Reply With Quote
1982 turbo diesel 310 :: 2013 Airstream turbo diesel 310 mayco Airstream Registry Discussions 1 07-28-2015 11:58 AM
1983 airstream 310 turbo diesel 63k miles eBay Watch Airstreams on eBay 0 10-28-2011 11:20 PM
82 310 Turbo Diesel EGT Gauge gcgreenwood Classic Motorhomes 5 09-27-2010 10:25 PM
1983 310 turbo diesel motorhome Illinois General Motorhome Topics 1 04-07-2007 06:36 PM
