Hello Folks:
My Argosy has got flat tires again, they are Generals and will be relaced when the snow stops. My question is, should I put jacks under the front to support the weight as its all going onto the rims. I don't care about the tires now I just want to protect the old girl.
The instrument panel is the only area I need to replace, anybody have just that?
I take it this has happened before? If it has, you might have a problem with the rims or the valve stems (or the neighbor kid). In either case the rims should not be hurt as long you don't move your rig. The tires will be trashed though by having the rims sit on the side walls..
Look into all posibilities for the flat tires.
