01-06-2018, 11:50 AM
#481
Slide Out Society #001
2007 30' Classic S/O
Somewhere
, South Carolina
Any improvement in lowering EGT's?
This sounds like a couple big steps forward so far.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
01-06-2018, 12:28 PM
#482
Silver Bullet
1986 34.5' Airstream 345
choctaw
, Oklahoma
Yes better/lower EGT. More power. Still it goes right on up when accelerating from zero to 70 going up hill. Hit the cruise, it shifted to 6th gear and the EGT dropped. Top boost (I saw) was 30psi.
This next week I'm going to take it to a shop w/lots of shop air and have them pressurize the inlet and check for leaks. If there is a leak I could gain a couple more pounds of boost and help the EGT.
I moved the starwheel in the fuel pump a quite a ways. I'll crank it back about half of what I turned it up because I do see more that a 'puff' of smoke on acceleration. That's wasted fuel and heat.
Might add that going up my long hill on cruise the speed didn't drop at all, the EGT stayed good and it didn't down shift.
01-06-2018, 03:16 PM
#483
Somewhere
, South Carolina
30! Wow, stock charger or????
Ok keep the improvements coming and it's Saturday nite, take the boss out for dinner.
S/OS #001
01-07-2018, 07:44 AM
#484
Silver Bullet
choctaw
, Oklahoma
I put a 'wicked turban wheel' in it.
01-07-2018, 08:58 AM
#485
Somewhere
, South Carolina
More air = happy engine.
Did the "Boss" enjoy dinner?
S/OS #001
01-07-2018, 12:50 PM
#486
Foothill Ranch
454 to Cummins
Good stuff!
What did you do to your Turbo?
The engine I have came with the stock H1C Turbo which I hear is good for 300hp but the Hx35 from later engines is better.
01-07-2018, 02:54 PM
#487
Silver Bullet
choctaw
, Oklahoma
Originally Posted by Keyair
Good stuff!
This is the wheel: http://www.thoroughbreddiesel.com/di...cked-wheel.htm
And I had to go with a different exhaust wheel housing. Was told, it's better housing/turban then the stock. Had to change it so the waste gate accurate would clear the block with the new and improved exhaust manifold I had go to so the turbo would clear the floor.
I don't know what 'normal' boost pressure is for these engines. Per injector size, this is a 240hp motor plus the wicked turbo wheel, plus the better flow exhaust manifold, plus the turbo exhaust housing/wheel.
Guy down the street has a dynamometer, but can't figure how it get the Silver Bullet to fix on it.
01-07-2018, 03:12 PM
#488
Somewhere
, South Carolina
That would be some video.
S/OS #001
01-10-2018, 01:19 PM
#489
Silver Bullet
choctaw
, Oklahoma
Well rats:<( Took the Silver Bullet to the 'race' shop and dropped $$$ to have them pressurize the inlet and does it leak! The thin wall aluminum tube I'm using is too weak to allow the claps to be tighten enough to stop the leaks. I ordered a cast aluminum 45 degree elbow and some more 3 inch silicon tube.
They left the straight fitting they used to hook there shop air to that did have a elbow with a bleed hole in it to keep the waste gate closed longer. The bleed hole works. Without it I lost 10 psi of boost
NOW the dash air blower's now working    Start by checking to power to the blower motor.
01-11-2018, 03:32 PM
#490
Silver Bullet
choctaw
, Oklahoma
The dash air blower had a loose ground. Wish everything was that easy to fix.
Ordered a cast aluminum 45 degree elbow and a meter of 3" silicone tube. The thin walled aluminum pipe will go in my scrap pile. Maybe the only air I hear rushing by will be from speeding down the highway now.
01-12-2018, 06:01 AM
#491
Somewhere
, South Carolina
10 lbs of boost is a bunch to loose. Get it back, soon.
S/OS #001
05-19-2018, 10:08 AM
#492
Silver Bullet
choctaw
, Oklahoma
AS motor home get together
I got the Silver Bullet all the way to Mesick, Mich. Over 1000 miles.
While in St. Louis I bought and installed stock injectors and fuel cam plate(have one in the tool box at home).
With the #8 cam plate I ran out of adjustment and still had too much smoke and high EGT.
With it back to 'stock' EGT don't get over 1200 degrees, and no smoke. Started opening up the fuel 'star wheel'. It's getting 12.5 mpg running at 65mph.
One of the guys here(Nick) said the injectors may be 'popping' twice at less than 300 psi which would cause the over fueling. Will get them checked when I get home.
05-19-2018, 10:28 AM
#493
Somewhere
, South Carolina
12.5 at 65. Is that happy dance time on shakedown trip?
S/OS #001
05-20-2018, 11:54 AM
#494
Silver Bullet
choctaw
, Oklahoma
Not so happy now.
Left this morning with hopes of getting to Terre Haute, IN. Stopped in Cedar Springs with diesel smell. Check and fuel return manifold is broken in two. Now I stay here till I can see if the Cummins parts house in Grand Rapides, Mich had the manifold Monday
05-21-2018, 07:38 PM
#495
Foothill Ranch
Ugh.
05-26-2018, 06:06 AM
#496
Somewhere
, South Carolina
Ok Mel, time for updates.
Gotta write the shakedown cruise journal.
We’ve read about a few repairs in route but how’s the overall? Pulling better up hills, actually able to pass stuff including a fuel stop noise level.
Gary
S/OS #001
09-28-2018, 06:30 PM
#497
1977 28' Argosy 28
Hacienda Heights
Interested in hearing more. About to cummins swap too
09-29-2018, 03:00 PM
#498
Silver Bullet
choctaw
, Oklahoma
Looks like I haven't 'undated' since the broken return line.
Got a new fuel return manifold and was back on the road that next day by noon.
Overall got 10 mpg. Not want I hoped for but far better than I ever got out of the gas'r.
I did put the larger injectors back in when I got home and have run 450 miles. EGT is back up just above what I'd like. Been looking for a Cummins guy that can reset the P7100 pump from 13 to 15 degrees BTC. My understanding is that will cool the EGT and boost the power. I've noticed that pump timing of 14-15 btc is one of the things higher hp engine have..... Along with different pistons and head. I haven't decided on the #11 fuel cam plate or just play with the stock plate. Been having issues with my new knee, so been laying low and not wanting to be on my hands and knees to tinker with it.
Had an old leaking, moldy building I emptied and took down. Now I don't have room for all my junk in my 2000sf shop, so in the process of building a new building to help house my woodworking equipment...... 2 tractors, 2 lawn mowers, welding equipment, 2 cars, 1 truck, bicycle shop, and of course the 'Silver Bullet'......... Sure am glad I have never been able to talk myself into buying a boat.
09-30-2018, 07:53 AM
#499
1977 28' Argosy 28
Hacienda Heights
You have any exhaust work done? Which turbo are you using? High egt could be from lack if flow. I will confess I am new to 12v but I have a few GM 6.5s TD that struggle with lots of issues.
10-04-2018, 01:59 PM
#500
Silver Bullet
choctaw
, Oklahoma
Exhaust is 4" with no muffler. As in straight pipe.
After I got home I put the bigger injectors back w/the stock cam plate. EGT is back just over want it should be. Looking for someone more knowledgeable then me to bump the P-pump up to 15 degrees BTC. I see that the higher hp 12 valve Cummins are 14.5 degrees. Some people say this will cool the EGT and boost the hp. If I do the change myself I'll have to pull the motor. If my new knee will ever get better I'll do that being I can't find anyone to do it for me.
One thing I have learned about the 12v Cummins: What the data plate says is about all you can got out of one if you're wanting it to last. Put a bigger turbo on and get more boost, blow head gaskets; Bigger injectors, high EGT/smoke; change the cam plate, high EGT/smoke.
I've been told that I need a #10 or 11 cam plate. I let the hot rod'rs talk me into the #8 cam plate and that didn't work too well.
