Old 07-11-2020, 01:44 PM   #1
Spartanguy's Avatar
Louisville , Alabama
Running AC continuously?
Hope everyone is well. Iím camping down on Dauphin Island in Alabama with a friend this weekend, got a good beach campground site, but itís hot out there.
Is there disadvantage to running my AC continuously from say 10am-4pm daily. It basically seems to need there.
I have 1 AC, with AC on it feels great inside. Awnings out.
Attachment 1
Spartanguy is offline   Reply With Quote
Old 07-11-2020, 01:58 PM   #2
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
As long as you have good voltage, that is what it was meant to do!!
ACI #7394
2012 GMC 2500 HD Duramax Denali
1976 31' Gone but fondly remembered
1976 22' Argosy
Hensley Hitch
CBWELL is offline   Reply With Quote
Old 07-11-2020, 02:08 PM   #3
2019 25' Flying Cloud
Pala , California
Hi,
I'm in the same position with 103į temps. My guess is it's better to set lower and have run longer than having more start ups as that seems to be the wear and tear part of the process.
But I may be wrong....
Trav
TravisH is offline   Reply With Quote
Old 07-11-2020, 02:39 PM   #4
The Aluminum Tent 3
pcskier's Avatar
2014 23' Flying Cloud
Park City , Utah
Originally Posted by TravisH View Post
Hi,
Trav
With 103 degree temps, it will likely run continuously whether it's set at 80 or 70 and won't have the compressor coming on and off. But even with lower temps outside, say 90, and the temp inside is set to 80 instead of 70, the cycling of the compressor would be pretty much the same. Set at 80, it'll shut off at 80 or 79...then back on when the temp rises a degree. Same if set at 70 (if it gets down to 70 inside.)
Peter
Instagram: @thealuminumtent
pcskier is offline   Reply With Quote
Old 07-11-2020, 03:39 PM   #5
Overkill Specialist
GMFL's Avatar
2020 30í Globetrotter
2014 23' International
Dadeville , Alabama
At present location, Destin FL. Outside temp 106. Full sun site. 2 AC running nonstop and I ain’t cuttin them off. Haha
Old 07-11-2020, 03:48 PM   #6
Long Island , New York
Bingo!
Peter
Old 07-11-2020, 04:01 PM   #7
2019 19' Flying Cloud
2006 16' International CCD
Front Range , CO
I was just wondering the the same thing.
Where I am currently located the humidity reading on my iPhone WX app has been showing 75 to 90 degrees with 80% to 95% humidity. If the AC is not on at night things inside my trailer have been literally getting damp! I know that sounds crazy. I am from Colorado and I think it is a lot "dryer" there?
Starting out, when inside the trailer I would have the AC set to 65 degrees with fan set to "auto." Once the interior was cooled down it would cycle on and off every 10 or 15 minutes.
This morning, I tweaked my back and I have been inside all day laying down watching movies or reading... with the fan set to "Low" and the AC has been running constantly for the last 12 hours!
I hope I am not ruining the AC unit.
I think I should shut it down before I destroy it...
trailerpup is offline   Reply With Quote
Old 07-11-2020, 04:19 PM   #8
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I rarely use the auto fan setting. Selecting a speed keeps it at that fan speed all the time. The compressor still cycles as needed. Keeping the fan on gives continuous air circulation and it's easier to sleep without it going from loud to silent if it cycles.
No, it won't wear out the unit.
2019 Ford Expedition Platinum
Old 07-11-2020, 04:20 PM   #9
2018 25' International
Slidell , Louisiana
Starting puts the most stress on the motors, fans and compressor, So running continuously is better than running even 30% of the time, and much better than cycling off and on 3 or 4 times per hour.
Brian
Old 07-12-2020, 12:30 AM   #10
Bingo!
Peter
Old 07-12-2020, 10:51 AM   #11
Spartanguy's Avatar
Thank you all and Iím so glad this is the answer !
Converter Fan Running Continuously tjwoods1 Batteries, Univolts, Converters & Inverters 0 04-02-2018 06:58 PM
Refrigerator fan running continuously boocanoe Refrigerators 12 04-19-2017 04:29 PM
Inverter runs continuously???? mwilliamsmd Electronics & Connectivity 20 11-01-2016 10:41 PM
AC/heat pump runs continuously unless shut off manually lsinclair Furnaces, Heaters, Fireplaces & Air Conditioning 3 08-13-2010 07:47 PM
Water Pump Runs Continuously craftsman Water Heaters, Filters & Pumps 6 12-01-2009 11:38 AM
