Old 08-31-2022, 09:55 AM   #1
1986 34.5' Airstream 345
Sunrise , Florida
Onan 6.5 Airstream 345
Help ! hello! Having a new problem with my generator starts and runs for about 15 minutes and quits ,if I try to restart again it won't start maybe next day or when is cool off , anybody had similar situation ? Thanks
Saint007 is offline   Reply With Quote
Old 08-31-2022, 01:30 PM   #2
2004 28' International CCD
Lincoln City , Oregon
Smokstak onan
Try this forum, Smokstak Onan. Include model and serial #. This site is a bunch of Onan hobbyists and technicians. Your current problem may be fuel or spark related, it may not be getting proper cooling, it may have a defective low oil pressure cutout switch, a high temp switch problem, some models must produce proper AC output to run. If low on oil, genset will not run. Depending on which model you have, these small 1800 rpm Onan gensets are some of the best ever made. They respond really well to a tune up, points,plugs, condenser, plug wires, air filter and oil change, make sure the brushes on the generator end are making good contact with the commutator and slide freely in the brush holders. If this is an older genset, as I suspect it is, Cummins, who bought Onan and changed the name, does not provide much support for them anymore. They may have parts, but unless you can luckily find an older technician who is familiar with these units, they may not know much about fixing and adjusting this unit.
Genboy is offline   Reply With Quote
Old 08-31-2022, 04:06 PM   #3
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Often posts get lost if they aren't in the most appropriate sections. Maybe ask the moderators to move to the classis motorhome section and you will get more 'hits' and possibly replies.
https://www.airforums.com/forums/f311/
martin300662 is offline   Reply With Quote
345 Onan Generator Switch issues Blammo General Repair Forum 0 12-22-2021 02:18 PM
1988 Airstream Motor Coach RV model 345 Onan Low Miles MUST SEE/LOOK NO RESERVE eBay Watch Airstreams on eBay 0 08-11-2012 07:00 PM
345 Motorhome :: 2011 Airstream 345 cowboy7877 Airstream Registry Discussions 0 12-27-2011 03:38 PM
L@K Airstream Mercedes Diesel Westfalia RV Class B OnaN SL@K Airstream Mercedes Diese eBay Watch Airstreams on eBay 0 03-28-2011 01:00 PM
1986 AS 345 MH Onan generator Jim Tyrney Airstream Motorhome Forums 0 06-18-2004 10:58 PM
