Good afternoon everyone, can anyone tell me which carb kit part number or rebuild kit vendor I could use for my Kohler 7000 7CM21-RV carb? any information would help. Want to replace needle, seat and bowl gasket for my Kohler, thanks Bill.
Thank you for the information, I purchased this 1986 Air. 34.5 motorhome that's been sitting for several years hence the carb rebuild. Hope to get it running soon. Next will be airbag replacement which looks like a challenge. Forum has been a great resource!! Bill.
Tried to google the model number and serial number on the 7CM21-RV GEN and seems there are several kits with different needle and seat. Also tried Kohler look up and this model is not in the system. Any thoughts? thanks Bill.
If it is, use the rebuild kit part number to find one. I'm not recommending this seller (just the first one I found), and see it being sold all over the internet including on Amazon.
Richard
11018
1994 Excella 25 'Gertie' Follow the build on Gertie!
1999 Suburban LS 2500 w/7.4L V8 'Bert'
1974 GMC 4108a - Custom Coach Land Cruiser 'The Bus' (Sold)
Thank you Richard, yes I saw that part number and did order this kit however the seat was shaped differently than the original which is tapered on the end compared to the new part which is flat. I googled it using the "Kohler 7CM21-RV" search and this is what I found also. I want to be sure I have the right part. Kind regards Bill.
Sometimes they update the design of these things as the years go on, and sometimes they just make a more universal kit that works with multiple models but looks like none of the original parts.
Guess you'll know when it arrives. At least it's not an expense experiment. As long as the fuel flow stops it should work.
Richard
11018
Thank you gentlemen, I did install this kit and the seat was different however the generator seems to run great so anyone else who buys this kit can know this does work as a replacement.
