Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums
Old 05-04-2022, 06:18 AM   #41
Boom Sounds's Avatar
1991 25' Airstream 250
Oxford , Oxfordshire
Originally Posted by Eric F View Post
how can I tell if mine is indeed a 475 (and not a 400)?
It's determined by the chassis length, check this doc for details.
https://www.gmheritagecenter.com/doc...-Motorhome.pdf
Boom Sounds is offline   Reply With Quote
Old 05-05-2022, 11:31 AM   #42
1976 24' Argosy 24
El Paso , Texas
Thanks!
Eric F is offline   Reply With Quote
FAST automatic overdrive transmission controller wmarsha Tow Vehicles 0 09-01-2009 09:38 PM
"Overdrive" for 370 noiva Mechanics Corner - Engines, Transmission & More... 20 12-10-2005 05:39 PM
GEAR VENDORS overdrive, same as units IPM Mechanics Corner - Engines, Transmission & More... 12 07-02-2004 09:13 PM
Overdrive (ie; US Gear) VS trans upgrade ... Hayseed Mechanics Corner - Engines, Transmission & More... 24 07-17-2003 08:19 AM
Opinions on Gear Vendors under/overdrive rdm Mechanics Corner - Engines, Transmission & More... 0 10-15-2002 10:36 AM
