02-23-2022, 02:48 PM
1976 24' Argosy 24
El Paso
how much mpg increase if I add overdrive transmission?
The guy who pulled the 454 engine on my 1976 argosy MH tells me that its TH400 tranny is in bad shape. He's suggesting that I either rebuild/replace the TH400, or upgrade to a TH700 (overdrive + cable shift) for $700 more.
Have others done this? How did it work out? What sort of mileage improvement did you see?
Eric
02-23-2022, 05:37 PM
1984 31' Airstream310
Honokaa
, Hawaii
We have one coach with the stock th475 non-od transmission and one with the same trans but an added Gear Vendors overdrive unit. Both get about the same mileage, but the overdrive is great to have. Just being able to keep up with traffic when I have to be on a freeway makes it worth it. The non-overdrive coach is a traffic hazard on a freeway.
02-23-2022, 05:46 PM
2022 25' Flying Cloud
2015 30' FB FC Bunk
2012 25' FB Flying Cloud
Golden
I personally would not change the original gearing on a motor home. Go back just the way it was engineered. If you are putting in a new HD diesel then I would still run some calculations before changing.
2022 25RBT FC, 50A Dual AC, Awning Package, 270W Solar, Convection Microwave. Ceramic Coat, Grand Lounge, 3" Lift, 16" Michelin RIBs, Multiplus II, Battleborn 400A, MPPT 100/50, Orion-TR 30, EasyStart (2), Easy Touch, AirKrafters jenRack, Onan 2500i, Truma Aquago Confort, Starlink, Pepwave, Parsec
02-23-2022, 10:00 PM
1972 31' Sovereign
Silverton
, Oregon
I wouldn't think a 700r4 would be a good idea. That's the forebear of the 4l60(e) box of neutrals.
a more modern 4l80E would be better with a standalone controller
"Daddy when's the trailer going to be finished?"
It's done. I mean mostly. It works anyway.
02-23-2022, 11:26 PM
2020 25' Flying Cloud
Chula Vista
Agree with the above. The 700 and 4L60 are derived from the TH350, good, but light duty transmissions. I would stay with the TH400/475. If you want that extra 2-3 MPG of the OD, insist on the 400's overdrive descendants, the electronic 4L80e/6L80e which would need a separate controller. And if you go that route, go with the 6L80e.
But the money you save by rebuilding the 400 will buy a lot of gas.
02-24-2022, 09:25 AM
2010 22' Sport
Sarnia
, Ontario
I am a retired GM mechanic, do yourself a favour and stay with the 400 transmission.
Pete
02-24-2022, 10:24 AM
1960 26' Overlander
Tipton
, Iowa
Keep it original, less flashy, but generally better reliability.
02-24-2022, 12:01 PM
1986 31' Sovereign
Miami
It takes “x” btu’s to move your rig down the road. All of the btu’s available are in the fuel so, while a different transmission or final gearing may be a smidgeon more efficient, fuel consumption will be pretty much the same in the end.
Sorta new (usually dirty) Nissan Titan XD (hardly paid for)
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
02-24-2022, 01:00 PM
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
It depends on the weight you are dragging around, and the type of roads you travel. We use Bella (a 20ft, weighed at 7000lbs) mainly on Interstates/motorways, and travel at around 70mph, so get 25% better gas with the GearVendors, just because 70mph without it was rev'ing the guts out of the non-OD box.
I would do the same swap in a heart-beat, unless I was changing to TBI and then I would use a 4L85E as the aftermarket controllers drive both TBI and transmission.
02-24-2022, 03:24 PM
2017 20' Flying Cloud
Williamson County
As mentioned the TH400 is stronger than the 700. The 700 was used mostly in 1/2 tons, and a few "light duty" 3/4 ton. For that reason I personally would not change it.
That said, the 700R4/4L60e can be modified to handle more power, but I don't think I have ever seen one behind a 454 V8, that engine is almost always combined with the TH400 & 4L80e
2018 GMC Canyon CCSB V6 Mallet Supercharger
2006 Chevrolet CCSB 2500HD 6.6T LBZ
02-24-2022, 07:22 PM
2021 30' Flying Cloud
Airstream - Other
Airstream - Other
Lady Lake
Agree
agree stay with the 400. built right it’s a good transmission. Jasper transmission has figured out the unit an has a good warranty program.
Pete
02-25-2022, 04:40 AM
1976 24' Argosy 24
El Paso
Thanks all for your advice. I'm gonna stick with a th400.
02-25-2022, 04:52 AM
2013 31' Classic
billings
, Montana
…yes….you pull in overdrive ..more transmission problems..
02-25-2022, 05:56 AM
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
Don't remember anyone talking about 'pulling'. The OP as a 24ft Argosy motorhome!
02-25-2022, 05:58 AM
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
In a 24ft your would have a TH475 (only a few early 20fts had TH400), so straight cut teeth. Make sure your mechanic knows the difference.
02-25-2022, 05:59 AM
Airstream Driver
1994 30' Excella
1992 35' Airstream 350
Austin
The answer to your questions depends on your intended use. If you are planning on doing a lot of mountain driving, up down 10k passes, the TH475 is the better choice. If you plan on going cross country using the interstate system, you will be a road hazard @55. Any speed above that will turn your rig into a a roaring beast running at 3200rpm or above.
The 4l80E is a fantastic transmission, but does require throttle position, by either tapping into the existing TPS of a fuel injection system or an aftermarket cable mounted sensor, which in most cases surrenders your cruise control useless.
Other than that, some rear mounting bracket, driveshaft length, shift gear linkage and trans line changes will be needed.
I personally would always upgrade to a 4l80e along with a throttle body injection system.
AIR #13
02-25-2022, 06:26 AM
2010 22' Sport
Sarnia
, Ontario
Have work and driven mid 70’s engine’s, I don’t think 1976 454 has enough power to utilize an overdrive transmission like an 4L80e. If you were to drop in a GM 454 crate engine with fuel injection and 4L80e you would be golden. Then you would have the PCM to operate the electronic controlled transmission and engine functions. Also an large increase of power and fuel economy. 454 engine in 1976 was only about 230hp and a little of 300 ft/lb of torque. Most modern day V6 engines done better than that today.
Pete
02-25-2022, 06:16 PM
Airstream Driver
1994 30' Excella
Austin
Pete
Always open to good info, since i was under the impression that 70's 454 was used all the way up to 1996. I do not think my 1992 350LE/4L80E has more than 230 HP
>>>>>Chevrolet developed three 454-cubic-inch engines for the 1970 model year: the LS5, the LS6 and the LS7, though the last one was not produced for the public in any vehicles. These engines were used in trucks from 1975 until 1996.<<<<<
AIR #13
02-25-2022, 06:51 PM
Airstream Driver
1994 30' Excella
Austin
Real life data: Stock 1983 454, carbureted with 4l80e and standalone controller.
AIR #13
