Wildwilly,
First I don’t own an AI or motor home. But hearing what the dealer has to say will be very interesting. Get exact details of what they did and changed etc.
Just this week I borrowed a slightly special clamp on ammeter and did several current draw tests on my trailer.
Here’s what I learned. Using a clamp on ammeter is very easy. Open clamp position over cable close clamp and read amps. I was getting data and down to 0.1 amps just messing around.
Pretty sure if you found that one battery to AI positive cable you could do same.
This meter also reads the typical AC, DC, Ohms, and more. It covers most anything you would normally want to measure.
But if you’re looking at one for this purpose make sure it reads DC amps that’s the kicker.
I bought one few yrs ago and missed the DC amp function by less than $20 or so. Tool box has space for a new meter and son gets a used good meter soon.
Gary
